Which lowering springs to go for?
theo289 Jul 26, 2013
  1. theo289
    theo289 Member
    293
    Hi All,
    Have an Audi A3 sportback 2007 with 18's RS6 reps - at the moment when i hit any kind of bump/ little bit in the road, my rear wheels are rubbing really badly. So now i'm at the stage of thinking about replacing the springs as there has been a lot of discussions on here about this - but which is best - H&R or Eibach?
    H&R Sport Lowered Spring Kits - Demon Tweeks - H&R
    Eibach Pro-Kit Lowering Spring Kit - Demon Tweeks - Eibach
    If anyone has any pictures/ comments on the ride, the response of the car with corners etc would be great.
    Appriciate all of your help as usual :)
  2. smurfworth
    smurfworth Well-Known Member Audi S3
    1,930
    542
    Got the H&R's, they feel better than standard however as you'd expect with anything thats lowered it bounces slightly. Doesnt really go low enough on the front, but i like hardly any arch gaps. all in all, very good and i'd reccomend.
    what offset are your wheels and have you removed the rear screws in the bumper?
  3. Dan_Mol
    Dan_Mol Member
    46
    Just bought myself some H&R. Reading the forums and a lot of searches they seem a better ride that the Eibachs.
    Fitting this week so will try get some pics.
  4. TDI140
    TDI140 Well-Known Member
    1,626
    174
    Sell you my H&R 55mm springs for £100 if i buy some coilovers soon if your interested in collecting frim derbyshire PM me
  5. TDI140
    1,626
    174
    Only been on car for about 6 months
  6. MTRL
    MTRL Split Grill!
    459
    52
    ^^^Good deal, good springs
    TDI140 likes this.
  7. theo289
    theo289 Member
    293
    Got a feeling they are 8J 245 18. Just looking for a reasonable ride which doesn't cause rubbing (which is what I currently have - and lots of it!)
  8. theo289
    theo289 Member
    293
    check the inbox :)
  9. smurfworth
    1,930
    542
    245's will rub like a ***** if lowered, you can just about get away with 225's on H&R's. any lower and you need to look at 205's or 215 to stretch them inside the arches. Also depends on your offset which will either be ET 45 or ET38
    g dawg likes this.
  10. theo289
    theo289 Member
    293
    Okay so if I go for 225, does it cause much rubbing?
    Thanks for the advise so far :)
  11. TDI140
    1,626
    174
    Ive got bentleys ET41 9J running 225/35/19 only rubs with 5 people otherwise its fine recommend 215's to avoid any rubbing
  12. theo289
    theo289 Member
    293
    as the current suspension on my car is stupidly spongy, if I were to have four people in the car, that causes rubbing. Do you find if you have four it causes rubbing too?
    thanks
  13. MTRL
    MTRL Split Grill!
    459
    52
    Here are some before and after shots of mine on H&R 55's:
    Before:
    After:
    Ride is a bit harder, handles a hell of a lot better in the corners. Much more fun to drive now. Very happy with the drop.
  14. theo289
    theo289 Member
    293
    They look very good! How is the ride? What size are your alloys?
  15. TDI140
    1,626
    174
    No rubbing with four and my wheels are wide as a mofo ! As most people know bentley rims stick outside the wheel arches on an a3 with 5 theres some rubbing not bad though four i havnt noticed any rubbing at all
  16. S3Alex
    10,734
    4,771
    Absolutely....I have 245x40x18s on mine,and it required a suspension rebuild to fit the lot under the car.
    Otherwise you need to resort to arch bending and silly amounts of camber.
    This will give you an idea of what it looks like....
    And what it took to get them under the arches......
    MTRL likes this.
  17. MTRL
    MTRL Split Grill!
    459
    52
    Alloys are 18" x 8J. ET 45.
    Running 225/40/18
    Ride is absolutely fine, its defiantly firmer.
    No problems with speed humps, no rubbing. Not had more than 2 people in the car yet though so cant comment on what its like with a full car, but I try to avoid having more than 2 people in there anyway. Scuffing up my mats with their feet, get the bus.
    I don't imagine there will be a problem.
  18. Beagles
    Beagles Member
    88
    I hate passengers as they are just messy and also ruin my mats!
    I have 18 RS4 reps, 225 40 18's and I think Et45 and it scrubs like a B***h on the back, screws removed too!!! Is pretty low though:/ ImageUploadedByTapatalk1375031352.036068.jpg
    Can kinda see how low it is in this. I'm on coilovers though!
  19. DPM
    DPM Site Sponsor Site Sponsor
    5,016
    205
  20. theo289
    theo289 Member
    293
    I've just spoken to a company called Performance 3000 in Yeovil and they are saying that if the car rubs a bit here or there, the ride would rub even more with 35mm H&R springs - so confused now :(
  21. smurfworth
    1,930
    542
    YOU CANNOT RUN 245 TYRES WITHOUT RUBBING
    Clearer now?
    maximum of 225 width, with a maximum offset (ET) of 45. so, you cant run et38 offset alloys without rubbing.
    Lowering your current setup will make it rub like nuts.
    change your tyres before lows.
    /thread
  22. theo289
    theo289 Member
    293
    sorry for any confusion but im on 225/40/18
  23. smurfworth
    1,930
    542
    right, what alloys do you have? any spacers? do you know the offset of them?
  24. theo289
    theo289 Member
    293
    unsure of the offset but they are replica RS6 alloys
  25. theo289
    theo289 Member
    293
    18's
  26. smurfworth
    1,930
    542
    then its gotta be a real low offset, my guess is et38.
    see mines on 225/40/18 8J, offset of 45 and on 50mm H&R springs, can have a full car and not one bit of rubbing occurs. The wheel can be so far up in the arch that the arches are inline with the top of the alloy and still absolutely nothing rubs.
  27. theo289
    theo289 Member
    293
    will need to try and measure it but in essence the car just touches the inner wheel arch lining - i want the 35mm drop
  28. theo289
    theo289 Member
    293
    8J ET 45
  29. theo289
    theo289 Member
    293
    everythings all done - spoke to Damian and ordered the H&R Springs :)
    Pics to follow!
    MTRL and Jonse like this.
  30. Jonse
    Jonse Active Member
    448
    49
    Looking forward to seeing the result :icon_thumright:
  31. Dan_Mol
    Dan_Mol Member
    46
    Just fitted my H&R's tonight, quick drive round the block tonight to check them over and seem good quality.
    Smooth ride at speed, slightly harsher on bumpy surface at slow speeds, no worse than S Line springs, saying that I did have a broken rear so clunk has also gone.
    Looking forward to testing them on way to work in morning.
  32. theo289
    theo289 Member
    293
    Sounds positive so far :) do you have any images?
  33. Dan_Mol
    Dan_Mol Member
    46
    No pics yet, was dark and wet outside when got finished, will snap one at dinner today. Sits better just need to choose the right wheels to fill the arch.
    Don't think you will be dissapointed with the H&R. Ride was fine coming to work this morning, haven't had chance to push it but overall impressions are good.
  34. theo289
    theo289 Member
    293
    Did you go for the 35 or 45/55mm drop?
  35. theo289
    theo289 Member
    293
    Okay so the springs are now on! first of all you can notice the difference on the rear and front of the car where it has dropped slightly - pretty nice stance and rather subtle!
    Ride:
    Well i'm quite a difficult to please guy however motorway driving - perfect, couldn't ask for more!
    City Driving: i am quite lucky to have been able to have driven the car immediately after collecting it from Bristol straight to Beckenham in London and London city driving; its not too bad, a little harsh and a few rubbs here or there but overall its not too bad!
    I will have to wait till next weekend when i am camping and have a car full of ****.
    Will put pictures up tomorrow once i have given the beauty a little clean :)
    Thanks all!
    Jonse likes this.
  36. theo289
    theo289 Member
    293
    As promised here are all of the photos:
    Before lowering:
    After lowering:
    i have had quite a bit more rubbing so thinking of removing the inner linings of the rear wheel arches :)
    wish you all luck :)
  37. MTRL
    MTRL Split Grill!
    459
    52
    Jesus, removing the arch linings is quite drastic. You shouldn't be getting any rubbing, you can remove the arch lining screw to see if that helps first.
    Also, looking at the before ride height I don't see how that would rub unless you are carting around a grand piano. Perhaps its a different issue.
    You have a side on shot of the new stance?
  38. BoutTime
    BoutTime Member
    95
    Have you fitted spacers as they look fairly flush with the arches?
  39. BoutTime
    BoutTime Member
    95
    Forget that last question. I guess they're a different offset being RS6 replicas.
  40. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    You sure it is the wheel rubbing and not the belly tray on the square speed bumps? You shouldn't be rubbing unless you haven't removed the arch screw.
