Which is the fuse for N80?
chris99 Mar 31, 2013
  1. chris99
    chris99 s3 driver
    54
    Anyone there knows which is the fuse for the EVAP purge valve (N80)?
    I just had my win reinstalled in 64bit version and not so easy to put ELSA back again..
    The plan is to put an inline fuel pump in the engine bay, powered from the old N80 connector and just upgrade the fuse.. Canister is already out, but now I have a long trip in the upcoming days, a tired fuel pump in the tank and don't have time and place to do it on an individual circuit, under the car. I will relocate the fuel filter to the engine bay after i get back (as I already got a filter for ibiza), and put the pump under the car, with an separate circuit, fuse, relay. Much apreciated guys!
  2. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    N80 is the 60 amp fuse on top of the battery,no need to upgrade that fuse,it also feeds,Lambda+heater,sai air inlet valve,air flow meter and ignition coils.
    thats APY engine code
  3. chris99
    chris99 s3 driver
    54
    Thanks a lot, AMK here but I guess it's the same. I knew it's shared with MAF and O2 sensors, never thought it's already 60 amps :)
  4. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    Yea nice and easy, amk will be same as apy :)
