Which is best a standard rev D or forge uprated diverter valve for stage 2+
brough74 Jan 26, 2011
  1. brough74
    brough74 Member
    423
    22
    Im looking to tune my S3 8P2 up shortly to stage 2+ and i have just checked my DV which has the part number 06F 145 710 G so which is the best upgrade either a forge DV which is a bit shiny or go for the rev D OEM one ?
    All the other bits are ready to go on apart from my stupid house boiler springing a leak which has knock the tuning back a month or 2.
  2. gynads
    gynads Member
    314
    I have a rev D and stage2+, no apparent problems, havent done any logging etc though
  3. navnayyar
    navnayyar Member
    756
    Get the forge one. Then you'd only need to change the spring and not dish out again if the oem fails
  4. gynads
    gynads Member
    314
    Bit of a difference in price between the two the OEM one would have to fail a fair few times to justify the price of the forge unit, I'm sure it's been documented there's no benefit of the forge unit over the rev D, a lot of the tuners even recommend it
  5. navnayyar
    navnayyar Member
    756
    Ok, it looks better lol
  6. brough74
    brough74 Member
    423
    22
    Yes it will probably the OEM one just to keep it a bit less discrete and the price diffference is quite a bit
  7. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    I am running 2+ with stock with absolutely no issues - logged 4 runs on VAGCOM at the weekend when installing the software and not a hint of a problem with the stock.
    But.........I got a good deal on a Forge unit inc the blow off adaptor so fitting that either this evening or this weekend, so will let you know the difference!
