Which induction kit?
wightman Oct 24, 2006
  1. wightman
    wightman Member
    61
    As some already know im after a re-map, but now im thinking to hold back and get an induction kit and maybe a system (de-cat)back before i do, to get the best out of the re-map at the time, so whats the general norm with induction kits? do peeps on here have them, if so what make? ive seen the average , Kn57i for around £90 , jetex do one for £72 , also a few pics would be nice so i can see what the crack is with the location of it.
    any help:think:
    cheers
    chris:rockwoot:
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    You will only gain noise from an induction kit,standard airbox can be modified to flow better with a larger pipe feed.Exhausts on s3's are good to start with,a3's benefit from having the front pipe and cat as well,not much gains from a cat back alone.If you decat then you will have problems with imissions,lamda faults etc.
  3. wightman
    wightman Member
    61
    Yeah thats what i thought about power gains , i would like a bit of noise tho, as for the zorst, could the lamda not be put in the same place? if a bespoke system was made? and as for emissions :whistle2:
  4. ANDYTQ
    1,184
    105
    It depends if your car has a twin lambda set up,ifit has you will need a cat of sorts.
  5. wightman
    wightman Member
    61
    ah i see now
  6. rich1068
    rich1068 Member
    674
    ABD LAN and a big eff off Green cone filter.
    Makes you car sound like Darth Vader with a cold (in a good way :o.k: )
    Little or no effect on performance though.
  7. Quattro_Lew
    Quattro_Lew All Torque
    206
    why not try out Jabbas induction kit? proven 4-6bhp gains
  8. wightman
    wightman Member
    61
    who sells the jabba kit then?
  9. Quattro_Lew
    206
  10. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    Lol, 'proven gains' heeeh!!
  11. Quattro_Lew
    206
    shhhhh ;)
  12. I didn't log it with VagCom, but I tried the stock airbox, a big K&N and no filter at all. I couldn't spot any performance difference. It only makes a difference to the sound, as others say.
    One good thing about more induction noise, is you can spot a dodgy DV easier.
  13. Timbo
    Timbo Slowest car ever round the Top Gear track?!?
    275
  14. ChriS3
    2,239
    27
    The BMC CDA makes a great noise. Cheaper than the Jabba kit too.
