which highflow manifold is best?
Dubstep Jun 19, 2012
  1. Dubstep
    Dubstep Member
    54
    Im trying to get the most out of the standard k04, ive got the dp, exhaust and ic sorted but am stuck on what highflow cast manifold to get. Ive read alot of mixed views on different ones and id like to know if anyone has any experience on the situation.
  2. badger5
    9,633
    2,071
    you dont have much choice of cast highflow k04 manis'
    oe...
    jbs-needs collector reworked to avoid misfire on #2 on some applications
    034-cracks
    alternates, tubular..
    relentless (whichever version is latest when you want one)
    tsr
    spiderworx
    frankenturbo
  3. Dubstep
    Dubstep Member
    54
    Thanks bill. Looks like the tubular mani route may be a better option for cost effectiveness. Anyone have an opinion on the frankenturbo ceramic coated mani?
  4. Lemon S3
    Lemon S3 Alex
    1,390
    41
    They have huge runners so the EGTs will be relatively low. Im planning on getting one when funds allow it.
  5. badger5
    9,633
    2,071
    in design terms I prefer the narrow angle merge collector of TSR's and Relentless over and above the others..
    No runner sharing is a good thing in my experience of these
  6. S3Zek
    S3Zek Member
    410
    Would say the tsr is a bit more robust than the relentless? And less likely to crack?
  7. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
    I would bloody well hope so at the price! Lol
    Pretty sure it's this one-
    K04 tubular manifold for 1.8turbo
  8. S3Zek
    S3Zek Member
    410
    Lol didn't look how much it was, you would be pissed if that cracked in a week.
  9. Customboy
    Customboy Active Member
    831
    43
    I'm going to be using a v2 relentless manifold mate but there are quite a few out there u can use just depends how deep into ur pockets u want to go lol but Sam byrant at the moment is doing a fantastic deal on the v2 manifolds due to the v3 coming out soon maybe consider that mate
  10. dre_S3
    dre_S3 Active Member
    756
    39
    that is a lot of money thought they were cheaper then that :ohmy:
  11. Sam_
    Sam_ Down under
    3,038
    480
    Yeah, waste of cash to fit a K04 and be limited to that later. Unless you're doing some sort of series where you can't change turbo, I just can't see why you'd get one over a XS power or just fit a T3 framed turbo and be done with it.
  12. badger5
    9,633
    2,071
    its made from a thicker wall material, back purge welded and higher quality welds, so yes, and the price reflects this i believe
    v3 relentless has its place... IF, they hold together
    each version has improved, but they must weld with backpurge and have full penetration on that thin wall tube else heat cycles and 900+'c temps will take their toll sooner rather than later i fear
  13. Jimgrim77
    Jimgrim77 Member
    957
    21
    agreed....when it gets hot, you do notice the power drop in the version 2
  14. Prawn
    11,708
    3,712
    What are you on about Jim :meeting: your comment has absolutely nothing to do with what Bill said. When Bill said heat cycles take their toll, he meant that it'll soon crack the manifold, not kill power.
    Also, if you're experiencing heat soak (which is what that sounds like) on a hybrid with an XS manifold, I'd suggest either your FMIC isn't up to the job, or you need WMI. I get absolutely no heatsoak or power loss at all, even in 28 degree ambient temps, it's always the same.
  15. badger5
    9,633
    2,071
    i was referring to 900+'c temps taking their toll on the manifold... collector area in particular, as it gets hottest as its the focal point of all 4 cylinders...
  16. Prawn
    11,708
    3,712
    'Ee gets Reet wAAARmm Ee Doo!!!!!
  17. Jimgrim77
    Jimgrim77 Member
    957
    21
    Apologies...was working earlier, miss read and typed nonsense. Been a long day
