Which Engine - S3
g60leigh Feb 8, 2010
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I have bought a 2001 S3and am going to collect it tomorrow.
    just wondering before I go and get it if there is a way of telling which engine version it has either from the chassis number or visually from a photo of the engine top?
    thanks guys
  2. Andrew@A.L.D
    3,879
    617
    Engine code is stamped into the head next to the cam belt side
  3. 1animal1
    9,978
    or you can check the sticker in the spare wheel well..... it has a KW figure that will identify the engine type, altho cant rem which the BAM is :)
  4. <tuffty/>
    21,572
    4,045
    AMK = 210, BAM = 225
    Largely academic to be honest, no attributable differences that a remap won't cure... If its the right car don't be put off by the fact its got 15bhp less if its an AMK..
  5. g60leigh
    1,674
    207
    Was hopin there was a way of checking from the vin
  6. <tuffty/>
    21,572
    4,045
    just undo 2 x clips on the top engine cover and lift slightly to see the engine code... clear as day...
  7. g60leigh
    1,674
    207
    I have not got car here yet so cannot check it physically yet
    Thanks again
  8. <tuffty/>
    21,572
    4,045
    Do you have any part of the V5 docs?
    Should be part of the engine number... also be able to tell by CO2 as well, 210bhp(AMK) is 224 co's and BAM is 226 co's IIRC...
  9. g60leigh
    1,674
    207
    no getting it all tomorrow
    I have the VIN number as I got it to perform checks on it, have the reg and V5 doc number and issue date along with date the car was 1st registered
    I am wondering if it is a 210 bhp or 225 bhp model.
  10. 1animal1
    9,978
    Tufts the label in the boot shows a KW figure...ie not 225 or 210...its more like 167 or in that region (cant be ***** to check)
  11. OllieH
    OllieH Member
    368
    Pretty sure the label says the actual engine type as I remember seeing BAM when I was looking under there earlier today.
  12. s3_stig
    s3_stig Member
    376
    86007 if you txt your reg to this number it will give you the cars spec from the factory
  13. JS1500
    JS1500 Howdy
    1,166
    10
    Will it tell you anything like factory fitted options?
    This is what it says on the website;
  14. GeneralWest
    GeneralWest Member
    168
    G60leigh, if it's not too late, send me your reg no and I can tell you what engine code you've got.
  15. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Phone up your local audi dealer and give them the reg or vin number they will be able to tell you
  16. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    you bought a car not knowing which engine it has or basically didn't care ?
    So basically, from reading above you are saying there are no differences between the 210 and 225 engine apart from the 15bhp ?
    2 cars being equal in every respect apart from engines, would have the 225 engined higher in price.
  17. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Yep, pretty much. Obviously there are small variations across the 4 different engines that they put in the S3s, but nothing that really matters. Maps were the main difference with the BAM.
  18. sportstractor
    sportstractor Chugger
    2,709
    and Varible vale timing no? which i hear doesnt do much, except on idle?
  19. finesse
    finesse Active Member
    2,805
    Not to hijack the original posters thread,
    AMK or BAM
    Does it really matter? Both have a facelift and from reading the forums, both AMK and BAM electronic VVT. Only difference is 15bhp....:noway:
  20. 1animal1
    9,978
    you would want the latest car if it was in budget...im guessing you have an AMK
  21. g60leigh
    1,674
    207
    thanks for all the help
    I have the AMK
    yeah I bought the car without knowing which engine type it was as it had all the spec etc I wanted and I think I got a good price
