Which DV?
audivro May 16, 2008
  1. audivro
    audivro Member
    Hi,want to go for a remap but will be renewing all the items which need to be uprated first.Looking at a new dv but dont want an atmospheric dv but at the same time want a tiny bit more sound than the standard unit.Does for instance the forge or similar give a slightly more noticeable sound?Used to be in the jap seen with a highly modded gt4 with a hks bov which made a fantastic noise more of a screech but got on my proverbials after a while.I have heard the rs boys coming into work with there forge dump valves which are way to noisey and quite annoying on road test:yes:!!
    Any ideas?
  2. DPM
    DPM Site Sponsor Site Sponsor
    4,939
    184
  3. docurley
    4,069
    85
    Or the 225TT unit will work well too.
  4. fermented
    fermented New Member
    19
    Ive got a GFB BOV that can be set to 100% atmo to 10% (or full recirc), seems to work well.
    if you want it to sound like your bonnet just exploded 100% does it, but the car thinks it's overheating and can go into limp mode lol.
    I run mine on 10%, while i push to full boost it gives me a little PSSHT.
  5. andyccr
    andyccr 2003 1.8T Sport Ebony Black A4 Cabriolet
    442
    Forge all the way :) Lifetime warranty
  6. stapo69
    stapo69 All hail the mighty quattro!
    969
  7. AUDI TURBO
    AUDI TURBO Member
    577
    IVE GOT FORGE 007 DUMP VALVE ON MINE GIVES SLIGHT WOOSH NOISE BUT NOT TOO LOUD
  8. Markey
    Markey Active Member
    2,175
    I bought the TT one as its so much cheaper than the forge unit and is just as goos IMO and will easily take remap etc.
  9. aragorn
    17,956
    701
    if you want to hear the valve then change the inlet tract. If you junk all the pipework thats coming off the stock airbox (the snorkel that runs to the grille etc) and fit a "performance" filter you'll hear it better, if you ditch the airbox completely and fit a cone it will be louder still.
  10. mac1403
    mac1403 Member
    972
    Forge 007..excellent after sales. Anything wrong and they will just replace it. 2 years after i fitted mine and they sent me a new piston and 'o' rings + grease for nowt....fantastic!!
  11. audivro
    audivro Member
    hi,many thanks for all the reply's,i do favour function before form and at £16 +vat i think the 225 tt seems to be the way to go at the moment especially after spending a mahoooosive amount on our wedding recently(and all worth it).seems a bargain.Thanks for the idea regarding the pipe aragorn could well be the best of both worlds that way.
  12. AUDI TURBO
    AUDI TURBO Member
    577
    when i had the 225tt dump valve on mine did perofrma at all well for me. forge 100% better and also as above siad after sales were 600% even sent me a key ring and extra springs out foc!!!!!!
  13. naefeart
    naefeart Bonkers
    164
    29
    Another vote for the Forge here. Had mine fitted by JBS when they did my chip. Sure the price was under £90 fitted.
    It does give a nice woosh noise when on the gas.
    Probably worth mentioning that it is recommended that you regrease it at least once a year iirc.
    N
  14. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    and again for the forge 007, sounds very nice after remap, got mine used with spring kit, very simple nothing much to go wrong, just unscrews to grease/service
