Which Dump/recirculating valve??
S3 Rav Feb 18, 2008
  1. S3 Rav
    S3 Rav Well-Known Member
    2,824
    30
    Hi all, have got an s3 remapped to 265 by revo, i have a recirc forge valve on think it the 007 non-adjustable one. does anyone know if this would be the best one, i know they also do an adjustable valve, would this be better or does anyone know any better makes?
  2. spannah
    spannah Member
    238
    From what i have read mate, everyone seems to be upgrading their dumpvalve to what you currently have on there.
  3. danotto
    danotto VAG HUNTER
    1,090
    yeah forge 007p are what most people have,i have a bailey dv30 which is pretty much the same as the forge item,and works well.
  4. A3_Turbo
    A3_Turbo Swaying towards IHI....
    1,464
    Forge 007P is what most people use, i have that and a BMC CDA with a custom cold air feed linked to it and it makes a really nice sound.
    Forge do a SlitR valve but from what ive heard it doesnt make any different noise to what the 007P does?
    J
  5. S3 Rav
    2,824
    30
    thanks guys thats helpful. i would like to get more whoooosh out of it though. do they do a kit that will increase this. the reason i was asking about the best dv is that forge do a adjustable one that seems to be more expensive. are there any actual gains to this one.?
  6. DPM
    DPM Site Sponsor Site Sponsor
    4,989
    201
    Forge do the Splitter valve which is adjustable that will enable more of a woosh noise but still run fine with the 1.8T.
  7. S3 Rav
    2,824
    30
    will that add any other performance gains to the dv i already have though? or is it just the fact its a splitter valve that makes it more expensive?
  8. DPM
    4,989
    201
    The DV you're using at the moment hasn't given you anymore performance gains and neither will this one. The Forge valves are just more duriable and better looking.
  9. S3 Rav
    2,824
    30
    k cheers mate. not happy with my s3 at present seems to be down on power. the turbo kicks in but doesnt feel the full wack...any ideas?
  10. danotto
    danotto VAG HUNTER
    1,090
    split boost hose?
    poor sparks?
  11. DPM
    4,989
    201
    What colour spring you got in the DV?
  12. S3 Rav
    2,824
    30
    could be. sparks should be fine. just booted it home one day from work and hasnt felt the same since. have had a quick check for loose pipers but mayb will have to have a more detailed look. i can hear the turbo kick in and the revs increase but between 3-6000 rpm the acceleration slows and can hear increased air which isnt the turbo if that makes sense
  13. S3 Rav
    2,824
    30
    im not sure. bought the car not longs ago which had already been remaped.what does the spring do
  14. A3_Turbo
    1,464
    Take it down to your local tuner where are you based?
    They'll stick it on Vag-com and check for any faults and then get it remapped your turbo will kick in better then for sure!
    J
  15. S3 Rav
    2,824
    30
    the cars already been rempaed to 265 bhp. got the diagnostics on it on saturday which didnt show anything
  16. pat@forge
    pat@forge New Member
    The valve that you have IS adjustable. It is accomplished by way of changing springs. The adjustable 007 is only different in that the manifold nipple is on the side of the valve cap and it can be rotated 360* (adjustable).
  17. S3 Rav
    2,824
    30
    ic so whats the difference between that dv and the more expensive one?
  18. ash_s3
    ash_s3 Active Member
    1,016
    The new (ish) forge SplitR valve sounds really good, my mate has one on his ibiza cupra. Considering one for mine, i used to have the tried and tested 007P
    The only difference between the 007P and SplitR is that the SplitR dumps some of the air into the atmosphere (typical whooosh noise) and the rest is re-circulated back into the system. where as the 007P is a fully re-circulating valve - more quiet
    Going to try my mates SplitR valve on my car sometime so i can see what it sounds like!
  19. Aky
    Aky Aky
    1,512
    I have a Hyperboost Compact on mine. Was cheap from AMD and for some reason Milltek promote them on their website.
  20. S3 Rav
    2,824
    30
    yea iv seen that they promote that. is it any good. does it make any sound or totally quiet?
  21. ash_s3
    1,016
    exactly the same as the forge 007p
  22. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    im selling mine if your interested?!!
  23. S3 Rav
    2,824
    30
    was just wondering what the difference was thats all .like i said im haveing a bit of trouble with my car at the mo almost feels like how a standard s3 would as aposed to one thats been remaped. the turbo kicks in abit later and doesnt feel as punchy?
  24. DPM
    4,989
    201
    As said, check the spring colour in the Forge 007P. If you're using the green spring then it may be losing boost and not holding it for long enough. If this is the case try the yellow spring which is the one we recommend for S3's and mapped S3's and also the one we're running on our own S3.
    HTH
    Damian @ DPM
  25. S3 Rav
    2,824
    30
    cheers damian will do that. is there any reason for the sudden loss though, that car was running fine up untill about a week ago?
  26. DPM
    4,989
    201
    It probabley won't be that then. You had it on the VagCom?
  27. S3 Rav
    2,824
    30
    what exactly vagcom? is it specific to audi? ive had the diagnostics checked through a laptop but its not come up with anything. getting my turbo clean out 2mos.see if that makes a difference
  28. scott_johnson
    scott_johnson Audiless
    876
    Thinkin of buying the splitter vavle of forges and wunderd if you get any power loss when its dumping?? and if its as good as a normal re-circ when its in full re-circ mode???? dont no if its chavvy either.... love the sound of a turbo dumpin though...
  29. S3 Rav
    2,824
    30
    good question thinking along exactly the same lines:icon_thumright:
  30. pat@forge
    VAG-Com logs with the SpltR are indistinguishable from those with a fully recirc valve so there shouldn't be any power loss.
    The recirc opening on the SpltR is slightly smaller than that of our 007 so theoretically there will come a point where the hybrid runs out of flow before the 007. Not sure when this occurs but during prototyping it was fine on our test car (337 aka 25th anniversary edition) at ~23psi... or roughly 1.59 bar.
  31. scott_johnson
    876
    cheers for that pat. so its safe to say i can fit one of these and not worry about power loss to put my mind at rest + wen i get bored or people start takin the piss coz i look like a chav i can utalise the full re-circ option without any problems??? thanx again
  32. S3 Rav
    2,824
    30
    my cousin has the spiltter valve on his 1.8t quattro and says he def feels the difference when it is fully open therefore more woooshhhh. has anyone else had the same?
