Which brake fluid?
Blacky165 Jan 19, 2013
  1. Blacky165
    Blacky165 Member
    37
    Simple question - which brake fluid should I use for my standard 2005 A3 8P 2.0l TDi?
    I presume 1 litre of Dot 5.1 would be ok?
    Thanks everyone
  2. wesmaster
    wesmaster Member
    300
    20
    I would use DOT4 ESP, otherwise problems with ABS unit.
  3. GuyJ
    GuyJ Member
    58
    13
    No No No. Use Dot4 :)
  4. GuyJ
    GuyJ Member
    58
    13
    Beat me to it!
  5. donna
    donna Member
    68
    from what i understand if your car is designed to have dot 4.1 then that is what should be used. thay cant be mixed
    dot 5.1 is more for race use,and has a higher boiling point also you may need to replace your brake hoses under the arches to steel bradied becouse the standard ones would swell becouse dot 5.1 has less give, therefore expanding the week point when the brake is pressed.
    thats what i understand. someone else m
  6. wesmaster
    wesmaster Member
    300
    20
    Had the pressure sensor issue?
  7. Blacky165
    Blacky165 Member
    37
    Thanks for all the replies! Fairly conclusive - I shall get some dot 4 instead. Thanks again everyone.
  8. JPK
    JPK Active Member
    303
    Rather than starting my own thread. It's time for a fluid flush and change on my A3. For 'fast road' use, just use genuine VAG dot 4 fluid? Have stainless lines and new rotors and pads going on at the same time but I've read that ABS/ESP units dont particularly like race fluids like Motul RBF660 etc? OEM holds up well in most circumstances?
  9. Sevv
    Sevv Pushing the limits..
    1,324
    120
    is Motul RBF660 okay to use ? i just order 1.5ltrs :(
  10. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Dot4 a must
  11. Sevv
    1,324
    120
    so what does it basically do to the ABS unit ?
