Which Boost controller????
Pat Nov 8, 2011
  1. Pat
    Pat Member
    515
    Since taking a break from the rebuild and parking the car up over winter im looking at buying few more bits..
    First of all im looking at a EBC..
    Just wondered what people suggest?? Been looking at the blitz dual spec
  2. Inertiauk
    Inertiauk Active Member
    574
    29
    Is it really a good idea to take the boost control away from the ECU? it monitors for high EGT's and other problems and backs boost off, often before serious damage occurs.
  3. Paradox1
    Paradox1 Active Member
    1,833
    88
    I'd say only get on if you have a big turbo or a hybris turbo.don't really need it if mapped properly with standard turbos
  4. <tuffty/>
    20,995
    3,762
    If tuned correctly then its not a problem at all... its a BT Pat has and good results can be had from a decent EBC... Bill has used Apexi in the past but thats on FWD BT cars where the gear limited boost is a must...
    A decent tuner should be able to map the N75 properly however and with AWD there is no real advantage to going EBC...
    Depends what you want I guess :)
  5. Prawn
    11,443
    3,338
    I ran a gizzmo MS IBC in the track car for a bit, sadly I sold it when I thought I was breaking the car, now I want another one :( it worked brilliantly.
    I'd quite like something with RPM based mappable boost, but I'm not sure the budget can stretch that far!
  6. S3Zek
    S3Zek Member
    410
    10
    Got a bran new one if your interested prawn :o.k:
  7. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    my mates HKS one is pretty trick on his 200sx. but i guess that could only be fitted to certain cars.
  8. hades-
    9,481
    646
    iv been useing the gizmo for ages in a few cars
    theres a few good options aswell
  9. Pat
    Pat Member
    515
    Ok lads thanks for advice. Gunna try one along with a set of cams
  10. Paradox1
    1,833
    88
    Let us know how it goes, how much am i would a hks or gizmo controller cost.
    any pros & cons for them?
  11. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Greddy Profec B-Spec II
