where's the n80 and help with vag-com codes please.....
shufti Aug 1, 2007
  1. shufti
    shufti Member
    211
    hi guys
    i got a 2000 1.8t avant tipronic, it seems to run perfect other than really bad fuel economy...... 16-22 mpg average.
    i done a vag com scan and got this back
    17965 charge pressure control valve positive deviation
    17834 evap purge valve (n80) open circuit
    i checked out the 17965 on the web and got back these possible culprits
    1. Activated charcoal filter solenoid valve 1 (N80)
    2. Secondary air inlet valve (N112)
    3. Secondary air inlet pump relay (J299)
    4. Wastegate Bypass Regulator Valve (N75)
    5. Fuel system diagnostic pump (V144)
    6. Recirculating valve for turbocharger (N249)
    so I thought I'd start with replacing the n80 as it may be the cause of both faults........ does anyone know where abouts it is in the engine and what does it look like? is it an easy replace?
    any other suggestions other than the n80?
    cheers
  2. meatychi
    meatychi Member
    261
    Vagcat.com
  3. enda1
    enda1 Member
    436
    whats your engine code
  4. shufti
    shufti Member
    211
    engine code is ANB
    that VAGCAT has nothing listed for an n80 or evap purge valve
    any other help/advice
  5. enda1
    enda1 Member
    436
    The N80 should be sitting on top of your airbox on the left hand side of the engine as you look in see this link to see what it looks like
    http://www.audi-sport.net/vb/showthread.php?t=42033
    If you send me a pm I can send you the pages from elsawin describing how the secondary air system on the ANB engine works.
    In the mean time you could disconnect the pipe from the in board side of the N80 valve. This will prevent any pressure build up that might affect the secondary air system.
    the N112 and N249 are located under the inlet manifold check to see that all the pipe work is intact with no leaks
  6. shufti
    shufti Member
    211
    what part would you replace first taking into acount my poor fuel consuption?
    any tests i can do?
    cheers
