Where to place jack stands(rear)
Mutinyno9 May 1, 2004
  1. Mutinyno9
    Mutinyno9 Member
    248
    when i lift up one side of the rear of the car, i look around for a spot to place a jack stand, and NOTHING!! Is there a place designated for them and i'm just not seeing it or am i missing something?
  2. cbass
    cbass Member
    144
    Ditto,
    where are they??? I was looking for them this weekend too.
  3. manikm
    manikm Member
    59
    anyoen?
  4. Mutinyno9
    Mutinyno9 Member
    248
    I haven't tried anything yet, but what about on the differential? Would that hold/or be safe?
  5. Markey
    Markey Active Member
    2,175
    According to the Audi manual on my (W) A4 reg there should be marks on the side of the car under the doors where the jacking points are.
  6. Mutinyno9
    Mutinyno9 Member
    248
    I already knew that, i need a place to put the stationary jack stands under the car so i can work under the car. Thanks for checken though.
  7. Markey
    2,175
    they can still go there as well. You may need to put a bit of wood on the top as well so that they dont dig in.
    Or use a couple of trolly jacks.
  8. Mutinyno9
    Mutinyno9 Member
    248
    I would feel a lot more safe when going underneith the car with stationary jacks rather than the crank jack or a hydrolic jack. I have these ramps that allow a car/truck to drive up them and works as a jack. It take it about 2 feet of the ground. I might try that if all else fails. I like your idea of a couple trolly jacks Markey.
  9. Markey
    2,175
    What i tend to do is put two trolly jacks under each side then place the free standing ones under as well and get a tight fit, so if one fails there is a safty net, i also put bricks under as well.
    The ramps are better though i have them too, once the car is one the flat bit at the top then it aint going anywhere.
    I know what you mean though it is worring when you are under a car, you think is that safe or will my face get squashed.
  10. Mutinyno9
    Mutinyno9 Member
    248
    I'll have to give that a try, thanks Markey
