where to i check my clutch switch im vagcom?
Ollie-B Mar 2, 2013
  1. Ollie-B
    Ollie-B Rockin' Shnit
    328
    As title thanks
  2. pauldazzle
    pauldazzle Well-Known Member
    1,132
    81
  3. Ollie-B
    328
    Thanks alot mine reads 111 clutch switch it is
  4. BahnStormer77
    BahnStormer77 BahnStormer
    2,771
    58
    Check vagcom again afterwards, my clutch switch was stuck and the brake switch looked okay, but as soon as I'd done the clutch switch, the brake switch failed...
  5. Ollie-B
    328
    Will do mate thanks
  6. pauldazzle
    1,132
    81
    Just replaced both the brake & clutch switches on mine recently.
    When you fit the new switch do not depress the pedal, & make sure the switch clicks when you twist it into position if it doesn't click it won't work.
  7. Ollie-B
    328
    Do ya pull them right out until there fitted then press the pedals?
  8. pauldazzle
    1,132
    81
    Just make sure the plunger is fully extended. Do not press the pedal down when fitting.
  9. Ollie-B
    328
    No probs, cheers mate. Dont suppose you have a link for a decent replacment do ya. I dunno which one to get thas loads on ebay some black some blue?
  10. pauldazzle
    1,132
    81
    Get a genuine VAG part from any VAG dealer or TPS.
