Where to get MAF from for my AEB
Oranoco Mar 3, 2008
  1. Oranoco
    Oranoco Well-Known Member
    3,862
    381
    Looks like my MAF is finally shafted. If I drive on part throttle the car behaves. As soon as I open the throttle and hit 0.7bar the car starts to missfire like a pig.
    I'm pretty much resigned to having to replace the unit now but keep getting quotes of £185+ for it. Seems a bit steep. Guy at the local VW parts place says they are very rare to go wrong which kind of goes against what just about everybody else has told me.
    Is there an alternative part or upgrade that I can use?
  2. 951
    951 Member
    530
    I got mine from euro car parts for about £80 (genuine bosch).
  3. Broken Byzan
    13,237
    465
    there are 2 for the AEB depends on the ECU you are running, one is around £80 and the other is the expensive one. I learnt the hard way, but make sure you buy a genuine one, as the ebay copies are **** ( in a word) i tried 2 and finaly resorted to buying an OE one as both the copies exibited different characteristics, none of the right
  4. Oranoco
    3,862
    381
    Euro Car Parts are quoting at £209 + VAT based on my number plate. :(
    Think I'll exhaust all other avenues before I pay out for that little number. Will be gutted if I part with that sort of money and it doesn't sort anything.
  5. Markey
    Markey Active Member
    2,175
    Cant you send it back ??
  6. macca
    macca Member
    525
    try audi dealership as they do them exchange and you know you got the right one then.
  7. Broken Byzan
    13,237
    465
    You must need the early one then 0280 217 112, thats the dear one sadly. Do you know what ECU you have fitted? As you may find the later/cheaper one will work
  8. Oranoco
    3,862
    381
    The part number given to me buy my Audi spares place going from the reg plate was 0280 217 112. How do I go about finding out which ECU I have? Whip the ECU cover off and look for a etching or sticker?
    Noticed last night on whipping the plugs out that they are very white which would lead me to think th eengine is either running very very lean or the plugs are too hot adn I should be using a colder plug. They were an uprated plug from my local motorfactors and I've never been sure they were the right ones. Wondering if it's worth buying some cheapy boggo plugs to sling in and see what happens.
    Can go right off cars you know.
  9. Broken Byzan
    13,237
    465
    Easiest way is to look on the top, or use VAG to read it. if its 557t its the dear one if its 558 its the cheaper one
  10. AUDI TURBO
    AUDI TURBO Member
    577
    i just checked with audi they DO NOT do one exchanged for aeb engines only for later ones i was qouated about £230.00 +vat!!!!!!!!
  11. Broken Byzan
    13,237
    465
    they do for the later AEb engines 98 on
  12. AUDI TURBO
    AUDI TURBO Member
    577
    mines a 1996
  13. AUDI TURBO
    AUDI TURBO Member
    577
    even pages dont list one
  14. docurley
    4,070
    85
    Can you not upgrade?
  15. AUDI TURBO
    AUDI TURBO Member
    577
    what upgrade the car?
  16. Broken Byzan
    13,237
    465
    On a 96 it is the expensive one as it has the older ECU in it, thats what the problem you had with the ECU types and the dealy in the "chipping". The older one isnt as responsive as the later one,i remember some of the problems had by an old forum user madkebab in getting a good ecu tune.
    If the turbo has to bome off for the actuator, as Docourley says can you upgrade the turbo perhaps?
  17. AUDI TURBO
    AUDI TURBO Member
    577
    maybe have too at later date but dont have the spondolies at mo. got respray, tinted windows and brakes to sort.
