where to buy rear diff mount
lief Jul 17, 2010
  1. lief
    lief New Member
    anyone know where i can buy a new rear diff mount or new bush if possible?
    thanks.
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    which one do you need? the rear plate that mounts to the subframe or the "front" rear diff mount?
    TBH I spent a wedge on a bling item on the front rear diff mount, works a charm but over priced, the rear diff mounting plate I tigersealed and it is rock hard now.
    I jack the rear up under the diff now without so much as a movement.
    tube of Sikaflex or tigerseal will do the job for a tenner
  3. lief
    lief New Member
    its the "front" rear diff mount i need, i already put poly bushes on the one on the back, i can only it in the us (034motor sport)?
    cheers.
  4. AndyC
    AndyC Moderator Staff Member Moderator
    719
    the 034 one is excellent, although not actually made by them... I fitted one of these (15 mins tops), I used their harder rubber carrier mounts and made a huge difference to the slap..
    replacing the front snub mount was well worth it as well...
    however its now highlighted the older other mounts.
