Where to buy new Fob?
Izzy1 Jun 29, 2009
  1. Izzy1
    Izzy1 Vorsprung Durch Technik
    395
    10
    hi guys,
    I need a new key fob for my car. where is the best place to purchase one? looked on ebay but can't seem to get my part number.
    my part number is.... 4D0.837.231A 433.92MHz
    cheers
    p.s it needs to be a 3 button fob.
  2. aragorn
    18,579
    868
    Audi?
    They're about 40-50quid for the fob part iirc.
  3. Cockney Boy
    Cockney Boy Member
    483
    As long as you have the same style it will work, but you will need VAG COM to code it up.
  4. Izzy1
    395
    10
    i currently have one which i brought from ebay but the code is 4D0.837.231K (not A)
    this will not code to the car. could it be a faulty fob?
  5. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    you sure batterys ok, the only fobs ive not managed to sync with b5 pumps are 4z0 ones, the one you have should work
  6. Izzy1
    395
    10
    batteries seem brand new. i'll replace and try again.
  7. inigoj
    inigoj Member
    263
    The flip key with these part numbers are all interchangeable:
    4D0 837 231
    4D0 837 231 A
    4D0 837 231 B
    4D0 837 231 N
    4D0 837 231 R
  8. Izzy1
    395
    10
    so does that mean the new one I have brought will not work?
    new part number 4D0 837 231 K
    original part number 4D0 837 231 A
  9. inigoj
    inigoj Member
    263
    I think that the '4D0 837 231 K' key is for year 2000+ A6/S6/RS6 & TT's.
  10. Izzy1
    395
    10
    think you might be right as it did say A6/TT in small print under the part number.
    looks like it's going back on ebay until i find the right one.
  11. A6SE
    A6SE New Member
    Bit of a long shot, but if you still have this I might be interested....
    Paul
  12. jcb
    jcb Active Member
    4,132
    13
    is it hard to recode?
  13. olds_kool
    1,094
    15
    not if youve got 2 keys
    turn ign on with first key
    close door and lock manually with 2nd key, press unlock button wait 6 secs press unlock again and its done
    swap keys and repeat but press unlock twice then wait and press again
