Where to buy LED number plate bulbs
Triple.O.G Feb 23, 2011
  1. Triple.O.G
    Triple.O.G Active Member
    1,113
    As above please, i just need to know which will fit and not throw up error codes, have my side lights and HID's so dont want any yellow on the car.
    Also might aswell change the fogs. can anyone suggest an LED bulb that will fit the fogs withour canbus error.
    Thanks guys.
  2. Dazmo
    Dazmo Active Member
    1,762
    No where, i have tired about 5 different places, ranging from £10 LED's to non error £40.00 LED's.
    The B7's always seem to throw up the error, unless you fit resistors.
  3. Triple.O.G
    1,113
    Aw thats wanky bum, i thought you could get some.
    What about Fogs? i think iv read you can fit sidelight LEDs in them? fitted mine the other day and they are amazing but now i hate yellow light.
    Looks gruby.
  4. Fahim
    Fahim Member
    278
    Fit HID fog lights like i have...! I LOVE them.
    to
  5. Triple.O.G
    1,113
    They look mint mate, where did you ge them and do they throw up any error codes?
  6. Fahim
    Fahim Member
    278
    I got them from Ebay, and no there are no error codes.
    What bulb are the fogs again? H11's or H7s? Just ebay ''HID HX X0000K'' the first X being the type of bulb and the second X being the colour rating i.e 6000k or 8000k.
    It was a 5 minute job changing them over, taking off the belly pan etc and installing the ballasts using cable ties under the front bumper etc.
  7. Triple.O.G
    1,113
    I'll check that out, will normal LED sidelights not just pop in?I'm sure iv seen people on here do that? Much simpler.
  8. oldoiler
    oldoiler Member
    47
    Just make sure that they are CAN BUS compliant lamps - then no faults, mine work OK. if you fit resistor's make sure they are attached to metal body NOT plastic otherwise will melt and poss fire hazzard !?!@:crying:
  9. Triple.O.G
    1,113
    I'm not messing with resistors, I will just get can bus side lights, I have just put them in my actually side lights and no errors so I'll get some of those. Are they H7?
    Thanks guys.
  10. Triple.O.G
    1,113
    Thanks guys.
  11. razza1
    razza1 Well-Known Member
    3,054
    804
    What LED's have you put in your sidelights, and where did you get them from?
  12. Triple.O.G
    1,113
  13. razza1
    3,054
    804
    Thanks, will get some then, as the yellow sidelights don't go with the xenons. With regards to fitting them in your fogs though, won't they be too dull/not give off enough light?
  14. Triple.O.G
    1,113
    For what? Alot of cars dont even have fogs, these sidelight bulbs are very bright i think they will be fine. ill post pics now.
  15. Triple.O.G
    1,113
  16. Fahim
    Fahim Member
    278
    Those sidelights are sexy hot.
  17. razza1
    3,054
    804
    wow, they're bright...should be fine as fogs then I would've thought?
  18. Triple.O.G
    1,113
    Yeah I think they'll be ok, if you turn on just your sidelights in the middle of the day you get a big White/reflection from whatever your parked infront of. I can't believe the difference they make!
  19. razza1
    3,054
    804
    can't wait to get them, as have DRL function but the yellow is too crappy at the moment. These will certainly make a difference.
  20. Triple.O.G
    1,113
    I see you've changed your sig now too Raz, ha ha it reads like mine except you got the big boy engine :) It's had alot done!!
  21. Triple.O.G
    1,113
    What K hids you got and are your DRL's White?
  22. razza1
    3,054
    804
    yeah, I'm pretty happy with it, except I'm with a 2.0TDI at the moment whilst AUdi sort out a leaking transmission box...:(
  23. razza1
    3,054
    804
    They're the Original Audi Adaptive xenons (i.e. they move as you turn corners to highlight the way you're going better), not sure on the K rating.
    The DRL function only turns the sidelights on, they're not seperate LEDs as on the B8 audis. Hence why I wanted to get whiter bulbs in there.
  24. Triple.O.G
    1,113
    Ah I see, my mate has them on his S3.
    I like my Tdi but if we had a second car I'd change mine and get a 3.2, I love the noise they make. The problem with a turbo for me is that there is every point in modifying them and for that reason only I will.
    There's no point tuning a 3.2 so a simple cat back and I'm done. Save some cash!!
  25. razza1
    3,054
    804
    it's never that simple though is it :)
  26. Triple.O.G
    1,113
    Ha ha NO!, i told the Mrs when i bought this car that because its a diesel i wont be doing anything to it.
    Look at my Sig, it says otherwise HA HA HA!
  27. razza1
    3,054
    804
    fitted this morning much better!!
    Just need to find replacements for the DRL though :(
  28. Triple.O.G
    1,113
    Sidelights? There good arnt they!
  29. razza1
    3,054
    804
    yeah, much better, just need to find ones that will replace the DRL bulbs now...
