Where is the RNSE SAT antenna in B6 Cab?
Steve_B Sep 9, 2013
  1. Steve_B
    Steve_B Member
    39
    All,
    My RNSE has 0 satellites detected so pretty sure the antenna is duff or the wiring.
    Couldn't find any definitive answer but a suggestion the OEM SAT antenna (for NAV) is in the boot lid and such the cable breaks through the rubber tube between the lid and body.
    Anyone know if this the correct placement of the OEM SAT antenna placement?
    many thanks
    -Steve
  2. s8craig
    1,759
    56
    In the plastic boot lid, chances are the cable is broken as it goes through the boot hinge and the antenna is OK..
    So you maybe can just repair the wire
    The GPS antenna has a blue plug on it disconnect it at both ends (nav & antenna) and meter the cable to see if it broken. Test the inner and outer cables.
  3. Steve_B
    Steve_B Member
    39
    Superb, thanks very much.
    -Steve
