Where is the Oil Pressure Switch on a 2.5Tdi ???
moveitnick Oct 11, 2012
  1. moveitnick
    moveitnick Member
    32
    Hi all, i would be grateful if someone could tell me where the oil pressure switch is located n the engine bay as i need to replace mine, hopefully the car will stop bleeping at me then !!!!! Many thanks in advance, Nick
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
    Next to the turbo on the distribution block from where the turbo takes it's oil feed ! You cannot miss it ! There's 2: one is the low oil pressure sensor, the other is the oil temp. sensor and there's also an oil level/quality sensor fitted on the bottom of the sump !
  3. moveitnick
    moveitnick Member
    32
    Many thanks for that, i shall have a good look on monday as i hope it is simple to fit, thanks again, Nick
