Where is the "max" mark??
Ads Sep 5, 2011
  1. Ads
    Ads License to drive
    8,230
    607
    Over the weekend I was having a look in my engine bay and I looked at the coolant reservoir and noticed there is no maximum fill-up mark.
    Am I missing something??
    Where is it?
  2. mike foster
    3,967
    Does there need to be one ??
    I use the 'seam' as the max line but I'm sure it can't be critical !:icon_thumright:
  3. N8
    17,163
    718
    I will check later!
  4. Ads
    8,230
    607
    Every other car I've owned has had a max line.
    Isn't it supposed to be pretty bad to overfill with coolant, due to the fact that hot water expands.
    I'd never fill it to the brim so i'll be ok, but I bet there's probably someone somewhere who would given the absence of a max indicator.
    It just stood out to me because it's the first I've owned without a max.
  5. Ads
    8,230
    607
    Ta mate!
  6. TM
    TM S-line SB
    144
    I normally fill till the middle of the reservoir.
  7. Martyn_V6
    Martyn_V6 Member
    41
    I did this the other day as i noticed mine was low. I think the max is the thick black bar just slightly above the min one. Thats what i filled mine to anyway. Could be wrong tho
  8. AudiJosh
    AudiJosh New Member
    Hi im new to this site lol. just fort id let u know the {MAX LINE} is the 1 just above the MIN on the bottle. i now cus its my day to day job working on cars... lol. But i want hurt to go to the seam on the bottle.
  9. paddy
    paddy Audi=No fault code, no idea
    5,152
    133
    The S3 and the 3.2 have a clear MAX line about 2cm above the thick seam. what does your manual say ? mine has a picture .
    If its like this one then anywhere in the shaded area between the lines is fine
    AUDI A3 2009 COOLANT BOTTLE | eBay
  10. Ads
    8,230
    607
    So basically mine has been overfilled by quite a lot then?? That's actually my tank in the first post.
    My local Audi dealer did that!
  11. 1animal1
    9,978
    B*****s!! I'd take it back and tell em you want a new car
  12. Ads
    8,230
    607
    Don't tempt me!
    Makes me wonder though, if they can't even fill up a coolant tank by the correct amount then what else did they get wrong!
  13. paddy
    5,152
    133
    Its an "expansion" tank Ads the level will rise and fall with temp. Level will change from hot to stone cold, it will also allow steam to condense
  14. Ads
    8,230
    607
    Yep, I know that, but the level you see is when the engine was cold.... therefore at its lowest level.
    I'll have to keep an eye on how much it expands by when the car is at its running temp.
  15. paddy
    5,152
    133
    If thats the position it cooled in you may well find the level drops as soon as the thermostat reopens. It will not necessarily drain back into the system as it cools but it might shortly after you startup ie run the pump :)
  16. 1animal1
    9,978
    like paddy says..... if i were you i'd wait until its cold, take the cap off and run it for a couple of minutes, this will give you the correct level
    donations for advice gratefully received
  17. Ads
    8,230
    607
    'thanks' donated. ;)
  18. danb986
    danb986 In awe of VCDS Team Daytona
    520
    60
    Mine's actually got a silver sticker on the bottle that moves the min line up a bit and covers the old min line.
    I asked Audi and they said it was correct and that they recommend filling it up to the seam line.
  19. afcjay
    afcjay Member
    436
    as said the line above the min line is the max. if i was you id just get a turkey baster and suck out the excess
    i posted a thread about the mess they made of my pollen filter and have just seen your thread. Tbh i dont know who at audi actually service the cars but basic things like this should be done properly.
    One things for sure,they wont be getting any of my money in future,ill get my 12 year old to do it for some pocket money.You never know he might make it to a audi master technician by the age of 14 lol
  20. 1animal1
    9,978
    as said above, it may be that the level isn't incorrect.... all garages use a technique of removing the cap when refilling coolant to gauge the proper level and aid air bubble removal. Check this before removing anything!!
    Having said that fitters are exactly that, fitters...a lot of main dealers fitters get instructions printed off for every job they do - few actually employ full on mechanics - so your paying for your stamp and guarantee its been done correctly..... use that to you advantage if you've paid ya money!
    simples
  21. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,226
    318
    i always fill it up to the base of the plastic line hanging down inside the bottle its got a small ball on it that is the correct line as far as im aware
    picy >>
  22. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Ads you big girl you lol :jester:
    The upper thicker line is the max. The lower one is marked as the min. Guess they didnt think they would have to mark the max if the min one is marked. You have too much in but as Paddy said let it run and see if it lowers. :friends:
  23. Ads
    8,230
    607
    Haha, thanks for the definite answer guys! ;)
    So basically, the max line is somewhere between 1) the line above the min line (thinking about it, this does make sense now!), 2) the seam of the bottle, and 3) the little "plastic line that hangs down".
    To be honest, I wasn't really worried about it, I asked more out of interest... but I've let mine run a bit now with the cap off etc and the level is still way above any of those max's.
    But at what appears to be its full expansion the coolant isn't too close to the top of the reservoir so I guess it's ok.
  24. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    You'll be fine.
    If you over feel the coolant bottle and the lid is working correctly, it will vent any excesses coolant out of the lid.
  25. page3
    page3 New Member
    That's what I've always been told. Certainly with my last car, it would find its own level after a few runs, and no two cars would be the same!
  26. ScottD3
    15,161
    1,121
    I've allways aimed for the full mark but never worried about going over it.
