Where is the fuse box in my A3?
sharma Mar 11, 2008
  1. sharma
    sharma Member
    78
    Hi,
    When using my indicators they work but they also cut off themselves and i have to indicate again. This is continually happening. I am trying to locate my fusebox in my A3. Does anyone know where this is? (its on a 52 plate).
    Thanks.
  2. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    there is a panel on the side of the dash (drivers side) as you open the door, the fuses are behind there
    Mike
  3. sharma
    sharma Member
    78
    Thanks, i just found that. The reason i wanted to know where the fuse box is located is because in my MK2 Golf there would be a relay there and that was normally the cause of the problem. I cannot see a relay here.
    Does anyone know what is causing me this problem? The indicator works fine sometimes, it cuts of other times, and sometimes when the indicators are on the pattern is rather strange. Also in the fuse box compartment there is big sticker which contains numbers for each type of fuse. However i cannot figure out which number is for which fuse?
  4. rodenal
    rodenal Active Member
    1,992
    The numbers can be found in your handbook - it doesnt sound like a fuse issue to me tho, more likely the stalk itself i'd say
  5. Nilz
    11,356
    894
    Sounds like it may be the relay
  6. AndyMac
    9,832
    46
    The relays are under the knee bolster on the drivers side.
  7. sharma
    sharma Member
    78
    I thought it may be the relay but the hazards seem to be working??
  8. HTC
    HTC Active Member
    3,428
    9
    Do the indicators remain on when the car is stationary? Has it anything to do with how the steering wheel is positioned?
  9. simonwjones
    simonwjones Member
    366
    The hazard warning switch has dual relays for the indicators and the hazard switch.
    9 times out of 10 strange indicator problems are caused by the hazard switch.
    Simon
  10. sharma
    sharma Member
    78
    Thanks for that, it was the relay. I read an old post here and it said the hazard switch has 2 relay's. One for the hazards and one for the indicators. I replaced the hazard switch which contains the relay's and it solved the problem.
