Where is the coolant level sensor?
drfeelgood Aug 8, 2010
  1. drfeelgood
    drfeelgood Member
    225
    Some say its on the right side of the engine block, "passenger side" and others on the front of the block next to the dipstcik? I'am slightly confused
  2. Biggied
    Biggied They called him mellow yellow.
    198
    The LEVEL sensor is part of the coolant bottle mate, If its the TEMP sensor your looking for it will vary depending on what engine you have, 1.8T will be on the right hand side (passenger) of the engine bay in a plastic housing bolted to the block.
    Cheers Ewan.
  3. drfeelgood
    drfeelgood Member
    225
    Its the amk 210 bhp S3 engine, i'm trying to determine if i need to replace it or not due to this annoying cold start niggle
  4. drfeelgood
    drfeelgood Member
    225
    I think i mean to put the coolant sensor, not the coolant level sensor which is attached to the tank. lol
  5. Dani_B19
    9,465
    435
    You mean the one located near the airbox? I.e. the green temp sensor that sits in a type of T-housing thats part of the coolant pipework?
  6. thorsy22
    thorsy22 Member
    308
    You got a pic dani as I've looked for a green sensor before and not found anything!
  7. Dani_B19
    9,465
    435
    No cheif, ill try and get one, you wont be able to really see the green as most of the body is hidden within the housing.
  8. Imteyaz
    Imteyaz 6th Gear
    535
  9. danger S3
    danger S3 Member
    376
    23
    i just replaced the temp sensor on my AMK S3 as vagcom said intermittent fault.
    it was really easy todo, its in a horizontal coolant hose between the air intake box and the block running front to back. mine was green and had a connector with 4 wires going to it.
    definitly worth changing if you are getting startup issues
  10. drfeelgood
    drfeelgood Member
    225
    I think mine is black thats why i cant find it lol, i think i have found it anyway, it has the 4 wire's going in, audi replaced my maf but the problem is still there.
  11. danger S3
    danger S3 Member
    376
    23
    aye its the 4 wire one, when I took mine out the shiny bit that sticks into the coolant had tarnished bits on it, its only just over a tenner, worth replacing
  12. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    My problem was the gauge was flying straight up to 90 after few mins of driving. Its dead easy to change, make sure you clean or replace the seal. A spot of WD on the terminals wont hurt ether :)
  13. 1animal1
    9,978
    coolant level sensor is in the water bottle, about £13 from the dealers IIRC...... coolant temp sensor is similar cost and located next to the airbox, plumbed into a large pipe with a big black clip holding it in
