Where is the cheepest place to get the one piece Valo Headlamps?
Andy.B Nov 17, 2008
  1. Andy.B
    Andy.B Member
    401
    As per question really?
    I have had a quote for new units from that audi breaker on ebay for £120 delivered is that a good price or not?
  2. aragorn
    18,579
    868
    There is (or was) a chap selling them on ebay for ~80 each
  3. Siena
    Siena Active Member
    2,626
    £214 delivered, for brand new units.
    Or of course, you're welcome to collect, at £199.75 the pair.
  4. joost
    joost Active Member
    1,169
  5. Andy.B
    Andy.B Member
    401
  6. Broken Byzan
    13,237
    465
    Andy, the actual cutout is still there on the non HID lights as i mounted my ballasts there too. OE hids use DS2 bulbs iirc, so if you have a H7 kit go non OEM HID.
  7. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    mine has a recess for the ballast anyway cant really see the benefit ongoing for the HID version, i have a pic of the ballast under the headlamp if u want
  8. Andy.B
    Andy.B Member
    401
    Thats the kit i have i have bulbs for H4 bi-xenon and H7 bulbs.
    So should i go for the cheaper ones then?:yes:
  9. stapo69
    stapo69 All hail the mighty quattro!
    969
    So can I buy the normal 1-peice A4 ones, the cheaper ones, and swap my xenons, ballasts etc from the 2-peices already on my S4?
    Looking at the ones joost posted from allparts.
  10. aragorn
    18,579
    868
    Not sure if the cheaper ones above are real Valeo lamps...
    Xenons say genuine, but the halogen ones dont...
    Stapo, you should be able to fit the projector and ballast etc from your pre-facelift lamps to a halogen set, but its quite a bit of hassle to take the lamps apart!
    I would be tempted to buy the xenon ones above, and buy a D2S bulb/ballast kit from hids4u, should work out quite cheap, assuming they are real valeo lamps!
  11. joost
    joost Active Member
    1,169
    I got my one piece halogen units from Allparts, both valeo units. Got the levelling motors from them too, also valeo.
