where is my thermostat ?
white.akita Mar 13, 2009
  1. white.akita
    white.akita Active Member
    322
    30
    hi all, i have a 2002 audi a4 tdi 130 i think the engine code is awx.
    i am going to change the thermostat but when i have read on this forum about it many people have said that it is at the front of the engine and the alternator has to be removed.
    i have just looked in my haynes manual and that states it is on the left side of the engine and no mention of removing the alternator, can someone tell me which one is correct ?
  2. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    i didnt think there was a haynes manual for these motors mate, what years does it cover? If its for the b5 motors the engines are different.
    The stat is usually found at the end of the big bore pipe coming from the radiator to the block, behind the alloy housing the pipe connects to, at the front rhs just under the alternator. Thats a petrol one however, I really dont know if the diesel is different, just never ever seen a haynes book for the A4 B6 models, but I may be wrong :)
  3. white.akita
    322
    30
  4. evilscotsman
    1,350
    14
  5. white.akita
    322
    30
    cant see them mate.
  6. evilscotsman
    1,350
    14
    ok mate sorry, here they are:
    water hose / (expansion tank > pipe union > radiator) / F >> 8E-3-500 000
    / diesel eng.: AWX,AVF,AVB PR-9M0 (1)8E0121055N
    water hose / (expansion tank > pipe union > radiator) / F 8E-4-000 001>>
    / PR-9M0 (1)8E0121055K
    water hose with quick- coupling piece / (expansion tank > pipe union > radiator) / F >> 8E-3-500 000
    / PR-9M1,9M9 (1)8E0121055P
    water hose with quick- coupling piece / (expansion tank > pipe union > radiator) / F 8E-4-000 001>>
    / PR-9M1,9M9 -1J0121142
    retaining spring
    / 2357121140
    plug / see illustration:
    919-40 / 3N 90316802
    round seal
    19,6X3,6 / 4032121142
    retaining spring / no replacement part / see illustration:
    121-05 / 7038121065BH
    water pipe
    / -4D0133335
    cap
    / PR-9M1,9M9 806B121687
    seal
    20,5X5,5 / 9078133335A
    cap
    / 10N 90588201
    allen key head bolt (combi)
    M10X25 / 11N 10005007
    hexagon head bolt (combi)
    M6X30-Z1 / 12N 90175203
    hexagon nut, shouldered
    M6 / 16038121086F
    water hose / (flange > oil cooler > water pipe)
    / AWX,AVF (16)038121086L
    / AVB (17)038121071S
    water pipe
    / 18N 01508311
    M8 / 21038121101
    water hose / (flange > water pipe)
    / 228E0121101C
    water hose / (radiator > water pipe)
    / 238E0121107C
    breather hose / (expansion chamber > water pipe) / no replacement part
    / 27038121133A
    flange
    I / 28037121688
    seal
    50X3,15 / (29)038121144A
    flange with sealing ring and quick-action coupling
    II / 30037121687
    seal
    36X3,15 / 31027121631A
    double stud with hexagon drive
    M6X22/M6X14 / 32N 90280901
    hexagon head bolt (combi) / see illustration:
    M6X22 919-40 / 36038121473
    breather hose
    / 371J0121093AC
    retainer
    / 38N 90500601
    hexagon socket head bolt with collar
    M6X22 / 40N 10292201
    spring-type clip
    A14X12 / 414B0422379
    spring-type clip
    16X1,2 / 42N 90655301
    spring-type clip
    17X12 / 43N 90655501
    spring-type clip
    23X12 / 44N 90687001
    spring-type clip
    B27X12 / 45N 90655801
    spring-type clip
    40X12 / 478D0121094A
    [​IMG](1)06B121111Fcoolant thermostat
    2.0ltr. / ALZ,AVJ,ALT, AMB,AWA,BFB, BEX ALZ,AWA 106B121111G
    coolant thermostat / no replacement part
    / AVJ,ALT,AMB, BFB,BEX 306B121119C
    seal
    56X3 / 5N 10124406
    torx socket fillister hd. bolt
    M6X20-E / 6N 01152423
    washer
    A6,4X12,5X1,6 / 706B121119B
    seal
    50X3,5MM / 8N 90735603
    I hope that helps mate, cant see the thermostat in place anywhere, do you know your engine code?
  7. evilscotsman
    1,350
    14
    ah that didnt post up like it looked on their page....
    Anyway find out your engine code (three letters) and i'll have a better idea.
  8. white.akita
    322
    30
    thanks for your time , engine code is awx.
    sorry ive taken so long to reply i have been asleep, i think im getting man flue !!
  9. evilscotsman
    1,350
    14
    hehe ok mate, will have a look.
  10. evilscotsman
    1,350
    14
    Got it! Your item of interest is number 6:
    WATER PUMP / 1.6-2.0ltr. / / / 1.9ltr. / / 4 cylinder: / ALZ,AVJ,ALT, / AMB,BFB,BEX / diesel eng.: / AWX,AVF,AVB
    water pump / 1.6-2.0ltr. / 4 cylinder parts detail:
    1 06B121011E
    water pump with sealing washer
    1.9ltr. / ALZ,AVJ,ALT, AMB,BFB,BEX diesel eng.: AWX,AVF,AVB ALZ,ALT
    (1) 06B121011EX
    / ALZ,ALT
    (1) 038121011CX
    water pump with sealing washer / F >> 8E-2-295 000*
    / AWX,AVF,AVB
    (1) 038121011G
    water pump with sealing washer / F 8E-2-295 001>>*
    / AWX,AVF,AVB
    (1) 038121011GX
    / AWX,AVF,AVB
    1 06A121011T
    / AVJ,AMB,BFB, BEX
    (1) 06A121011TX
    / AVJ,AMB,BFB, BEX
    1 06B121011H
    / AWA
    2 06B121119
    seal
    72,5X4MM / ALZ,ALT,AWA
    (2) 038121119
    seal
    57X4MM / AWX,AVF,AVB
    (2) 06A121119
    seal
    53X4MM / AVJ,AMB,BFB, BEX
    3 N 90945001
    hexagon socket head bolt with shoulder
    M7X21,5-SP /
    6 044121113
    coolant thermostat
    87C-102C / AWX,AVF,AVB
    7 038121119B
    seal
    50X4 / AWX,AVF,AVB
  11. white.akita
    322
    30
    thanks alot, i have read a few posts saying that the alternator needs to be moved or swung out of the way but the haynes manual doesnt mention anything about the alternator.
    i will have to have a good look in the morning, thanks again.
  12. evilscotsman
    1,350
    14
    no problem mate. the alternator will definately be in the way of that area but not a big job to remove surely.
