Where does this Wire go?
CarbonBlack Jan 30, 2014
  1. CarbonBlack
    CarbonBlack Member
    Well I've replaced the Coil Pack Harness all the way to the ECU Plug. When removing the old Harness there was a Wire going down to a Sensor that I couldn't get to so I just snipped it off lol. Now the new Harness is in but I don't know what to do with the Wire. It's a Brown Wire that was brazed into a whole junction of Brown Wires up near the Coil Pack's. It goes down behind the back of the Engine somewhere to a Sensor & the Sensor is a 3 Wire. The other 2 Wires going to it ran the length of the Harness all the way back to the ECU Plug so I didn't have to do anything with them. It's not the Speed Sensor because you get a new 1 on the new Harness & I've plugged that back in already! If this Brown Wire is just a Earth (all Brown's were Brazed together) can I just earth it out on the Car somewhere?
  2. andy68
    andy68 MORE POWER Silver Supporter
    150
    46
    without pictures little hard to say, gut feeling it is the oil level sensor in the sump.
  3. robin_bga
    robin_bga Member
    50
    Hi, Is it coming from the new wire harness from the coil pack.
    Bcoz as far as am concerned, the coil uses 4wires.
    If all the 4 are on then just connect it to the other browns.
    Brown in Germany is Ground / Battery -.
  4. CarbonBlack
    CarbonBlack Member
    Cheers mate, my names Robin as well lol. Yeah I thought it might just be an Earth, so I should just be able to earth it anywhere to a good earthing point? It does look like it runs down to the Oil Level Sender, knew I should of got the other Harness!!!!!
  5. robin_bga
    robin_bga Member
    50
    Wow, you know Robin means Great.
  6. CarbonBlack
    CarbonBlack Member
    As far as I'm aware mate it means 'fame', 'bright, shinning'
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Get a room... ;)
    Almost deff its your oil temp sensor, it does get stuck behind the transfer box/engine when trying to get the loom out
  8. robin_bga
    robin_bga Member
    50
    S3dave what do you mean by "Get a room...;)"
  9. CarbonBlack
    CarbonBlack Member
    I think he wants to hook up with you hahahahaahaha
  10. robin_bga
    robin_bga Member
    50
    Thats unacceptable am Male so maybe female.
  11. Spatula
    Spatula A4 B6
    264
    25
    :wub: It's a forum romance.....
    The Two Robins.
  12. robin_bga
    robin_bga Member
    50
    What's wrong with u guys, in Africa we do believe in same sex its unholy & very dangerous.
    Lets focus on cars please.
  13. CarbonBlack
    CarbonBlack Member
    I'm Robin..... not Robyn lololol
  14. robin_bga
    robin_bga Member
    50
  15. Spatula
    Spatula A4 B6
    264
    25
    Ha! I agree though, more than likely oil temp sensor.
    It's getting pretty hot in here...
  16. CarbonBlack
    CarbonBlack Member
    I wouldn't know, I've cut the Wire to my temp sensor lolololololololol
    s3dave likes this.
