Where does the OE sub live on a B5 Avant...?
MaverickTDi Jan 26, 2013
  1. MaverickTDi
    MaverickTDi Active Member
    564
    41
    As in the title, where does the original Nokia sub woofer live on the B5 Avant's?
    Thanks.
  2. Mackers
    Mackers Member
    291
    behind the boot trim on the left of the boot (opposite the fuel cap), if you take off the access panel, and look in the hole and towards the front og the car, the black plastic it the "BOX" that it is in.
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
  4. MaverickTDi
    564
    41
    Cheers for the pic mate, now going to have a look to see if it's actually there, CD changer wasn't so I'm guessing this won't be either!?
  5. aragorn
    18,661
    877
    early cars didnt have it, but i think yours should seeing as its a '98.
  6. MaverickTDi
    564
    41
    I'll have a nosy in there anyway, I'm not 100% what my car should have tbh as it was a run out of the PFL on an S plate.
  7. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    to be fair it's hardly a sub anyway, just a bit of mid-bass gets it sounding a bit nasty... [it's made of tupperware plastic]
    you can see the side / top section just removing the pass. side cubbyhole cover without taling off the whole side panel.
  8. MaverickTDi
    564
    41
    Cheers peeps for responses, just checked and to my surprise its still there!
    My next question, would a Bose sub from the S4/RS4 slot straight in?
  9. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,038
    785
    No. With the standard setup the AMP if you can call it that feeds the rears speakers, and the head unit does the front speakers. With the Bose setup the AMP feeds all the speakers, so you would have to run the front speaker wires from the brown connector to the rear, and you would also need to run 2 wires for front left/right audio out to the AMP. Your also going to have to cut off the plug going into the current amp and and fit a new connect compatible with the Bose AMP.
    You should also replace the speakers as the Bose speakers are 2ohm, and the standard speakers are 4ohm, they would work with the 4ohm speakers but it's best if you have the correct stup.
  10. aragorn
    18,661
    877
    Bose is ****e anyway, buy a proper amplifier and proper subwoofer.
    You can pick up decent quality kit on ebay for buttons.
