Where does the combi valve vac hose go?
Bad Sir Culation Dec 9, 2013
  1. Bad Sir Culation
    Bad Sir Culation Member
    287
    17
    It's disconnected on my car. Should the hose be plugged back in? If not, should it be plugged as it isn't currently?
  2. Dani_B19
    9,258
    379
    It should be connected under the inlet manifold manifold off a small vac nipple. If its not then you need to find out whats on that nipple
  3. Bad Sir Culation
    287
    17
    Damn. I don't know where to start then, as I was looking at it tonight and couldn't see where it would go. I need pictures lol.
    In this photo from the other thread:
    you can see the hose from the inlet to the DV. I *THINK* that the hose from the FPR is going to the inlet next to where the DV hose goes. Does that sound correct so far?
    You will also see the black hose going into the t-piece on the DV hose. I do not know where this black hose goes, what it's for or why its plumbed into the DV hose. Perhaps this goes to where the combi valve hose should go?
    Is there any good reason to do this?
  4. <tuffty/>
    21,161
    3,837
    Looks like a fairly poorly executed N249 bypass... there is a guide in the FAQ sticky that could help you tidy it up a but... APY engines are a little more involved as they have secondary air (the pipe loitering about off the jobber on the side of the head...) most peeps just remove this altogether to simplify the whole thing... later AMK/BAM S3's didn't come with SAI... its an emissions thing... won't affect MOT as its more for controlling emissions on cold start...
    Look in the FAQs and have a read of the N249 bypass/delete thread...
    Couple of reasons for doing this... makes the DV more responsive and cleans up a lot of the pipes that can split etc and cause other running issues... however... there is no real need to do it if you don't want/need to... most people do it as they are getting rid of split pipes etc already so a full clean up of stuff and replacement with silicon just makes it easier...
    The N249 is used as part of the ECU protection functionality... its a switch over valve... the DV is opened by vacuum and kept closed by boost... if the ECU detects an issue then it can use the N249 to switch to a vacuum feed from the vacuum store (plastic container that is missing from your picture) and operates the DV to dump boost while closing the throttle to reduce load...
    You lose this with the bypass but tbh the ECU can hold its own without it... biggest issues being more leaks and bad maps... I'd be more concerned about leaks and bad maps than re-plumbing the N249 back in..
    You do need to leave it electrically connected though as this messes with adaptions and can make the car fail emission test at MOT time
  5. Bad Sir Culation
    287
    17
    Thanks Tufty. I've actually read through that, but thought I didn't need it as a result of this already being bypassed. Should I be looking for somewhere to plug this combi valve back in?
    I'll go back through that thread if you say it is going to yield the answers I need, but I could have sworn there was no mention of the vac hose for the combi. It is possible I am going mad, what with the amount of stuff I am having to jump on with this car all at once!
  6. <tuffty/>
    21,161
    3,837
    Lets get the terminology straight here... by 'combi' valve I am assuming you mean the grey valve in the centre of your pic above... if so this is the N249 valve
    The valve just needs to be plugged in electrically (as it is currently)... no need to pipe this up at all as this is now 'by passed'... just cable tie it out the way.. :)
  7. Bad Sir Culation
    287
    17
    Ah no, I know what the N249 valve is (now, thanks to you guys on here!), no what I mean is the round item to the right of the FPR. It has a dark vac hose connected to it that isn't going anywhere now. I thought it was an EGR originally but then saw it referred to as a combi valve a couple of times during searches. Seems I may have got my wires crossed on its name.
  8. Bad Sir Culation
    287
    17
    Anymore for anymore? :p
  9. <tuffty/>
    21,161
    3,837
    Thats the Secondary Air Injection valve... bin it off...
  10. Bad Sir Culation
    287
    17
  11. <tuffty/>
    21,161
    3,837
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/88299-sai-removal-guide.html
    Its used for emissions on cold start... binning off means less clutter, less pipes etc to leak, less to go wrong
  12. Bad Sir Culation
    287
    17
    Thanks Tuffty, much appreciated. It's far easier to find these guides when you know what the parts are actually called!
  13. Bad Sir Culation
    287
    17
    Just one more quick question; if I leave the valve in place for now, should I plug the vac line on it, or just leave it unplugged?
  14. Bad Sir Culation
    287
    17
    Bump in case anyone can answer this for me.
  15. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,829
    677
    If the car is running right and there isn't a check engine light then I would leave it for the moment until you do a SAI removal (if you do one). That's just me though, I don't like to fiddle with things that aint broken because I will tend to brake it!
