where do you buy your turbos from?
limbo118118 Mar 21, 2013
  1. limbo118118
    limbo118118 LORD
    498
    53
    anyone enlighten me on where everyone gets your turbos from?
    all iv seen are the gt3071r's on pagparts..... but they seem pretty pricey :s
    or my other option is a tdo5 hybrid off ebay for around 500-600.... only problem i havnt heard off anyone using these :s
    any advice?
    im looking for 400bhp idealy :) thankingyou!
  2. <tuffty/>
    21,572
    4,047
  3. limbo118118
    limbo118118 LORD
    498
    53
    thanks! what setup would you reccorment tuffty? i see you know your stuff! like which 3071 setup with which mani? btw im not doin the stroker kit
  4. <tuffty/>
    21,572
    4,047
    the TSR tubular manifold seems to work well... check StaceyS3's build thread for some ideas on that... I don't know what your planned budget is but for a reliable 400hp it won't come cheap
    Have you a budget in mind?
  5. limbo118118
    limbo118118 LORD
    498
    53
    Yeh iv sent a message over to stacey about that thread, im still reading through it!, im not sure really ino its a couple grand, like im ordering the rods kit next week. Then i was thinking : large port head/mani , injectors , custom tip an dp , supertech exhaust valves, piston rings, and a wellycooler insted of my forge one. Anythin else youd reccormend? Thankyou
  6. <tuffty/>
    21,572
    4,047
    Manifold, turbo, custom downpipe etc will see you a couple of grand at least... supertech valve train will be best part of a grand by the time you have got a large port head and had it sorted with new guides etc, gaskets and seals etc will stand you a couple of hundred, mapping of course...
    Inline fuel pump is a must at this power level and you would also be best looking at getting an inlet manifold too...
    I have no idea how much I have spent but 4 to 5 grand sounds more realistic if you are doing the work yourself
  7. limbo118118
    limbo118118 LORD
    498
    53
    Yeh i knew its guna be alot! :) why im saving now to get it all done over winter! Can i not get by with just doin the exahust vavles? Or do i need inlet ones aswel?
  8. James TQ
    James TQ Member
    561
    Clutch and flywheel will probably need to go on the list
  9. Andrew@A.L.D
    3,879
    617
    I've seen one 600 bhp done with just the exhaust valve but i have no idea how long it lasted with them
  10. <tuffty/>
    21,572
    4,047
    You want the valve springs ideally as you won't be able to take the revs up high enough... std valve train should be ok for the occasional excursion to 7.5k but for reliability then a full setup is needed... std exhaust valves are sodium filled, supertech are inconel... guides will need looking at on whatever head you use as these wear and cause issues...
    Obviously there are others that have done this power level without doing supertechs but I can't see the point in just changing the exhaust valves... you can always do it at a later date of course and detune the setup to suit until you can afford it... this is what I did..
  11. Prawn
    11,575
    3,546
    THE best thing about going in tufftys car is not the sheer stupid speed, but the sense of naughtiness watching the rev counter sail straight off the end of the clocks round to nearly 8k :)
    big turbos like to rev :)
  12. Andrew@A.L.D
    3,879
    617
    I know what you mean
