Where can i get 25mm spacers from?
Andy.B Jul 25, 2007
  1. Andy.B
    Andy.B Member
    401
    Im on the lookout for some propper hubcentric 25mm spacers for my T-sport, I want the ones that you bolt to the hub then then in turn turns the spacer into a stud conversion. I can find then all for jap cars but not for Audi's.
    Any ideas where to get a set from?:confused::thumbsup:
  2. Jimbo.King
    Jimbo.King Active Member VCDS Map User
    269
    50
  3. DPM
    DPM Site Sponsor Site Sponsor
    4,938
    184
    We can do H&R ones for you, what PCD is it from and to?
  4. cliveh
    cliveh quattro in the bones
    30
    Try Philip Walker - PW Motorsport
  5. Andy.B
    Andy.B Member
    401
    I just want 25mm spacers which are the usual 5x112 with a 57.1 center bore.
    The only reason i want bolt on spacers is the fact at 25mm id rather be using double fixings then just longer bolts :happy: in my own mind its safer.
  6. DPM
    4,938
    184
    That's not a problem either, i'll PM a price!
  7. Andy.B
    Andy.B Member
    401
    Just ordered a set of H&R 25mm and 35mm spacers from DPM @ a very good price indeed. Will post up the results when i get them :) Uber wide stance comming up...
  8. turboaudi
    turboaudi Member
    58
    thinking of doing the same mate . how much you pay ,, post some pics up when done
  9. Baker21
    Baker21 OEM+ A4 Avant
    79
    25mm should look pretty wide.....depending on your offset.
    Running 20mm on the back of the Mrs' Avant at the moment with a ET35 offset and they look about spot on!!
    Spacers are one of the better things to buy for any car IMHO!!
    Look forward to seeing the results!!
  10. Stringster
    Stringster Missed gear
    390
    Look forward to seeing these as well. Very interested in getting a set.
  11. Randomjim
    Randomjim Active Member
    2,752
    What wheels have you got? Also looking forward to seeing this.
  12. Andy.B
    Andy.B Member
    401
    You have to remember guys i have the wide archs on my car so can get away with huge spacers.
    For those interested i have the new look RS4 alloys in 8x18, they are all running on a 225 tyre. So when the time comes i have got these spacers to suit wider tyres on the front and the rear, I think i could get away with a 245 or if a 255 will fit on a 8" rim rear and 235 front.
    This is all purely cosmetic to fill the arches better as the 18's look lost in them at the mo.
    Havent looked into how the wider tyres will affect the handeling, but i know by widening the track it "SHOULD' give me better stability for cornering.
  13. stapo69
    stapo69 All hail the mighty quattro!
    969
