Where are the glow plugs? (A3 2.0TDi)
LSH Nov 8, 2009
  1. LSH
    LSH New Member
    23
    Hi all, as a novice to diesel engines, would someone be able to help me locate where the Glow Plugs are on an 8p A3 (2006)...?
    A picture would be very handy! :yes:
    Thanks in advance for the help,
    Luke
  2. PW-Motorsport
    PW-Motorsport Member
    396
    Remove the cam box and you should see them.
    Remove the single electrical plug and use a deep section socket to remove the heater plug.
  3. smbAudi
    smbAudi Member
    93
    out of interest why do you need to know, is it struggling to start after 3 years?
  4. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Mine came out with :
    15057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
    Might have to change the glow plug I guess.
    Could anyone kindly supply the part number, and perhaps some pictures on where exactly to find the glow plugs?
  5. Crunch
    Crunch Member
    118
    Loads of modern Diesels throw glow-plug faults, mine did when I first had the car, it started fine and there is nothing wrong with it, since I had the fault cleared it's not come back. Infact mine was cylinder 3 aswell.
    If it starts fine then I wouldn't worry.
  6. SAiLO
    1,075
    62
    But what if it leads to a more serious error? Maybe I'm just paranoid but better safe than sorry.
  7. Crunch
    Crunch Member
    118
    Well it's up to you obviously but I think it's just a waste of money.
    Worst case scenario............car is hard to start.
  8. LSH
    LSH New Member
    23
    Mine threw up the similar fault...but the car sometimes does not like to be started again when warm, but is fine from cold. So I thought the best bet would be to switch the plugs around and see if the fault code changes (especially as the car is on 90k+ miles)?
    The car did throw up an engine management light a few times when I got it (which I believe could of been EGR related), but after again clearing it a few months ago it has not come back (light on dash). Could this potentially throw up a glow plug fault?
    Thanks again,
    Luke
