When should my fuel light come on...
symun Jun 21, 2011
  1. symun
    symun Member
    147
    had my audi 1.9tdi P reg a few weeks now and have been doing some average mpg tests, putting in a set amount and running it to a set point on guage then putting in again, not the prefered method but i cant afford to brim it...
    Anyway, the needle goes right down into the red but the light hasn't come on, i know the bulb works as it comes on with keys in ignition.
    Need to know if it is going to come on or is it going to run out.
    So far its averaging nearly 50mpg with a tuning box fitted, just not sure if i have a faulty dash..
  2. aragorn
    18,490
    855
    Mine comes on with about 2 gallons left in the tank, and the DIS reports "0 miles left" with about 1 gallon left in the tank.
    I never pay much attention to the needle when it gets low, as the DIS and fuel light gives me the information i need.
    I always brim the tank, the only time i wont is if i've had to stop at a motorway services thats charging stupid money for fuel.
    IMO having to drive to the petrol station 5 times to put in a tenner of petrol uses more fuel than just filling the tank once with 50quids worth of petrol. Plus i hate filling stations, they're invariably full of morons, so the less time i spend wanting to kill them all the better!
    If you really want to find out if its broken, fill a fuel can with derv, stick it in the boot and keep driving until either the light comes on or it stops :p
  3. symun
    symun Member
    147
    Cheers, as it happens it came on earlier and it binged so it works.
    What is the DIS, and why havent i got one.
  4. aragorn
    18,490
    855
    Presumably because your car is an early lower spec model?
    I think earlier low-spec cars just had four or 6 big square lights in the middle of the dash, whereas the higher spec models got the DIS, which is an LCD panel that replaces those 4/6 lights.
    Later cars all got the DIS afaik.
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    DIS - Driver Information System.
    Its the red/black display in the middle of the clocks.
  6. symun
    symun Member
    147
    I have the two screens the bottom has the outside temperature the upper one shows nothing, how do i get this to work.
  7. ScottD3
    15,162
    1,123
    DIS
  8. aragorn
    18,490
    855
    The upper screen is probably the radio display, and presumably you have an aftermarket head unit.
  9. jonnycraig
    jonnycraig Member
    157
    Sorry to highjack guys I also have the DIS'less version with the lights but at the bottom I dont have outside temp (I have an aftermarket stereo so not worried bout the radio display) any one got any ideas why theres no temp shown, it def has the temp module between the bumper and the rad.
    Jonny
  10. symun
    symun Member
    147
    Looking at the pic its obvious i have the older style with just the 4 lights and 2 strips with the bottom strip showing temp in red and the strip above doesn't do anything.
