When is the timing belt due to be replaced?
gordybaillie Nov 26, 2009
  1. gordybaillie
    gordybaillie Member
    77
    Hi
    I have a 55 plate S-Line 2.0tdi. When is the titming belt due, I have searched google and would appear as though it is 75k miles, can anyone confirm this?
    Thanks!
  2. rowdyboy
    rowdyboy Member
    804
    19
    It's all stated in the front of your service book, or a quick call to the main dealer will tell you for definite.
  3. kidashley25
    kidashley25 New Member
    Audi A4 timing belt should be replaced every 50-70,000 miles. Car makers have specified the replacement intervals for timing belts. In this database you will find these timing belt replacement intervals along with a little technical information regarding the valve configuration - interference or non-interference. In an interference engine, the valves and piston share the same air space. They never touch, unless your timing belt breaks or skips, and this is a catastrophic failure that requires removing the head and replacing bent valves. Non-interference engines do not risk this contact if the timing belt goes. Nonetheless, either can leave you stranded, so regular timing belt replacement is very important.
  4. rowdyboy
    rowdyboy Member
    804
    19
    That is a very comprehensive answer to a simple question! Lol
