When did sidelight bulbs change from bayonet style to 501's?
au_sjo Feb 10, 2012
  1. au_sjo
    au_sjo Member
    102
    Hi all,
    Could anyone confirm when the B5 A4 changes from bayonet style sidelights to 501's? Was it with the facelift headlights? Mine is pre-facelift and has bayonets.
    Wondering if it's possible to change to 501's without changing headlamps?
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,713
    162
    Must be facelift headlights as my pfl car has fl headlights in with 501s.
    Does the bayonet holder just push into the headlight? If so, cut some 501 holders off from a scrapyard and connect up and fit.
  3. au_sjo
    au_sjo Member
    102
    Yeah it just pushes in to a rubber grommet. I don't know if the size is comparable. I'll have a look, I have both types of bulb.
    Thanks Dan.
  4. Bradderz_1988
    3,952
    235
    Mines facelift and has 501's
  5. aragorn
    18,373
    829
    I always thaught they were all 501 with the exception of Facelift S4's.
    Facelift S4's got H6W bayonets in an attempt to make the sidelights look less yellow against the HID dip beam!
    Looking at ETKA, prefacelift cars WITHOUT front fogs got T4W bayonet bulbs. The pre-facelifts WITH front fogs got a 501 wedge.
  6. au_sjo
    au_sjo Member
    102
    I can confirm that my pre-facelift A4 has bayonets and no foglights, so that aligns.
