Wheels rubbing
Jay4 Sep 20, 2007
  1. Jay4
    Jay4 Member
    51
    I have a 2.5tdi quattro se and have recently fitted a set of 18's et35 with 225/40/18 rubber. I noticed a couple of days ago that the front of the front wheelarches have been worn away slightly and snapped the small mudflaps also. It has to be the wheels rubbing against the arches but they don't touch anywhere on full lock and they don't seem to touch when the suspension is under duress, but obviously must do.
    I was wondering whether anyone else has had a similar problem?
  2. Randomjim
    Randomjim Active Member
    2,752
    They shouldn't be rubbing, how wide are they?
  3. Jay4
    Jay4 Member
    51
    8j wide. i think they are rubbing from the inside of the wheel when on full lock, whist cornering.
  4. dan_b
    dan_b Member
    263
    Is the offset (ET) value correct, perhaps you need spacers?
  5. jase0851
    jase0851 Member
    789
    dont have any probs with mine and they are 235/35/19 same offset aswell
  6. Jay4
    Jay4 Member
    51
    as far as i'm aware et35 should be fine
  7. Randomjim
    2,752
    That offset is fine, maybe you should take a wheel off an check the offset's correct. Normally it's stamped on the inside of one of the spokes.
