Wheels / Rims - Sizing and Spacer Advice
NME Apr 7, 2011
  1. NME
    NME Member
    150
    19
  2. jsws3
    jsws3 Member
    440
    not sure but i have a set of rotiform blq finnished in graphite gray right up your street ?
  3. N8
    17,163
    718
    No you don't want those CHs or the Rotis :shutup2::laugh:
  4. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    speedlines ftw
  5. N8
    17,163
    718
    :wub:
  6. Yaks
    Yaks Member
    181
    Offset works the opposite way from what you think it would - a low offset sticks out further, a high offset sits in further.
    Therefore a 35, will stick further out than a 45, not further in, so no, you don't want a spacer with the 35s
  7. Smoothie
    Smoothie Active Member
    1,431
    As said mate spacers only take away from the ET as in ET45 with 10mm spacer becomes ET35! But I've seen A3/S3's run ET35, they have a but much poke for me though
  8. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    I'm currently Runnin ET50 BBS CH 18 with 10mm spacer on mine. I've had to take the screw out in the arch to stop rubbing. so I wouldn't want to go any lower than ET40.
    Saying that.. I'm sure suspension also has something to do with it...
  9. FranA3
    7,228
    320
    defo mate
  10. NME
    NME Member
    150
    19
    Yeah, N8, there are a few options out there at the moment, and I'm keeping an eye on them!
    Thanks for the info guys, helps to know what the crack is with wheels and how they fit. Did a bit of reading before, and just got my wires crossed on the distance increase vs. decrease.
    So, what do you guys reckon is the lowest ET you can run without ANY rubbing issues on my car then?
  11. NME
    NME Member
    150
    19
    Right, so ET 40 might be the lowest to aim for...
    Sound.
  12. HIGGINS
    HIGGINS Member
    528
    15
    it depends on the width of the wheel and the size of the tyre
  13. N8
    17,163
    718
    Yeh it depends, you can run 9J and ET41, i.e. Speedline/Bentley width/offset but you need to be running a 215 like so:
  14. IanS3
    IanS3 Interweb creep
    306
    45
    Not 100% correct N8 as I run a 9J et42 with a 225 :happy:
    like this
  15. N8
    17,163
    718
    Maybe 18"s are different, but Mikey's A3 with Bentleys and 225s rubbed like............
    He was all the way down on weitecs as well -65mm
  16. IanS3
    306
    45
    Must be down to the 19's, because mine only catch on real big compressions and I am 5mm off the bottom on FK's, either that or he was lower than me.........which I very much doubt!
    I am gonna try 19's soon to see how they sit
  17. IanS3
    306
    45
