Wheels - refurbishment
Karcsi Sep 25, 2011
  1. Karcsi
    Karcsi Member
    426
    During A3 ownership some years ago I managed to run over a kerb and dent the rim of two wheels. I replaced them, but gave refurbishment a try myself.
    They've been sitting in my shed for the last 6 years - one finished, and the other just needs a coat of paint. I haven't the heart to throw them out before asking whether anyone wanted them - as a replacement or for a full sized spare.
    Before:
    After:
    Neither were / are cracked or buckled, but I can't say whether the damage was more than would normally be repaired. However, if anyone would be interested, and can collect from Bedfordshire, I'll finish the other one off and be quite happy for them to be taken off my hands.
    I also have a part used tyre (about 5mm left), but it has been sitting in the shed for 6 years and I am sure rubber has a shelf life, but happy for someone to take that as well.
  2. moag
    moag she's no d-turbo
    821
    35
    Out of interest what filler did you use? I fancy doing a DIY refurb on mine when i get the time
  3. Karcsi
    Karcsi Member
    426
    I used this stuff (or something similar):
    Halfords | Loctite Repair Express Power Putty
    It is in two parts that you kneed together and apply. Very hard once set (10-15 minutes), so don't put too much on as it will take some time to work down again. I used a Dremel and then wet and dry. Overlap slightly, to get a smooth transition. But IIRC, I had to use the primer to get that right.
  4. dav150n
    dav150n Member
    43
    i might be interested as one for a spare? would you post??
  5. Karcsi
    Karcsi Member
    426
    If you can arrange it, sure. If you search for alloy wheel postage costs there seems to be a good couple of alloy wheel couriers. About £15 for a wheel, it seems.
  6. N8
    17,163
    718
    I can sort it for £10. PM me.
  7. dav150n
    dav150n Member
    43
    Pm's sent.
  8. ST09
    ST09 Member
    319
    17
    What grit of sand paper did you use ?
    Sal
  9. Karcsi
    Karcsi Member
    426
    240 for the filler / primer initially and then down to 1200 - using very gentle pressure by the end.
