Wheels Offsets
stoakseya4 Sep 3, 2009
  1. stoakseya4
    stoakseya4 Active Member
    1,221
    Quick question?
    My OEM wheels are ET20. I run 10mm spacers to. This makes the wheel the equivalent of ET30?
    There is a small anmount of space available between the tyre/wheel and arch. Presumably if I went to an ET45 wheel, the wheel would actually extend beyond the arch?
  2. technics100
    technics100 Active Member
    850
    25
    Is it not the other way about, the higher the offset the further into the arch the wheel sits. 20mm ET with 10mm spacer equal 10mm offset.
  3. silversurfer
    silversurfer Member
    223
    Could you take your spacers off and buy some 15 or 20mm spacers..? Hopefully that will fill the gap
  4. dannyFR+tdi
    dannyFR+tdi Member
    212
    Thats what im led to believe
  5. jwhat
    jwhat Member VCDS Map User
    541
    I've heard that too.
  6. silversurfer
    silversurfer Member
    223
  7. paul20v
    paul20v Audi fanatic
    1,113
    They would be ET10 this is minus as the diagram shows till you get to 0 offset then it becomes positive offset all the time the wheels are sticking out further and further .
  8. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    it's the other way around (to Stoaksey's original comment)
    ET20 + 10mm spacer = ET10...
