Wheels- I don't get it!!!!!!!
sat1983 Sep 24, 2007
  1. sat1983
    sat1983 Member
    848
    15
    Can anyone explain what all the numbers mean??
    What's this ET all about???
    What wheels fit the A3?? Most i've seen are ET43 and ET45?? Which genuine OEM wheels scrub?
    Some guy on edition 38 forum is selling genuine RS6 wheels (18") because they are scrubbing on his mk5?? Surely the arches on the mk5 golf are the same as the A3 8P?? Why would they scrub??
    Don't worry maars still on for those spokes!!
  2. .:R2theT
    .:R2theT Dreaming of Boost
    50
    Wheel and Tyre Bible!
  3. gordybaillie
    gordybaillie Member
    77
    sat1983 - the RS6 wheels are my old wheels, I had these on my 2004 A3 2.0 tdi sport and they fitted perfectly.
  4. sat1983
    sat1983 Member
    848
    15
    Why dont they fit on a mk5 tho- or was this an excuse on his part!
  5. si_reading
    si_reading Member
    168
  6. maars
    maars Full speed ahead
    576
    After much searching I've just got my 19s.
    My OEM 18s are 7.5x18ET54 (which hopefully sat1983 will be buying).
    My new 19s are 8.5x19ET48. But with the extra width I'm worried they'll stick out the front arches. Help!
  7. dipstic
    dipstic Member
    384
    Think you will find that your new wheels will stick out more by 6+25= 31mm (et diff+1j)
    Might have been safer to have kept width the same then the et diff would have only been 6mm (further out) then used spacers to increase track width.
    Hope they fit
  8. maars
    576
    Unfortunately they only came in ET48 an 8.5J width. ******.
  9. sat1983
    sat1983 Member
    848
    15
    Ouch Maars can't you try them for size asap? I would!! All this ET talk is much more difficult than I thought!
  10. maars
    576
    sat1983 - that's what I plan to do this weekend! Fingers crossed they'll fit otherwise they'll be up for sale pronto.
  11. sat1983
    sat1983 Member
    848
    15
    Do I gather that if they don't fit- no 20 spoke wheels for sale?:laugh:
  12. dipstic
    dipstic Member
    384
    Did your supplier say they would fit?
  13. dipstic
    dipstic Member
    384
    What size tyres are fitted
  14. sat1983
    sat1983 Member
    848
    15
    Disptic- what ET are we looking for on an A3 8P?
  15. dipstic
    dipstic Member
    384
    Think the standard et is 45-49 but try this site use the wheel wizard should give various dimensions for diff models
    http://www.bkracing.co.uk/
  16. sat1983
    sat1983 Member
    848
    15
    But what does this mean, how would ET 44 or 50 fit then?? It's that i don't get!
  17. dipstic
    dipstic Member
    384
    If you look at the wheel wizard on that site and I used my 8P S3 as model of car it gives me an et of between 45-56 now I assume from that my maximum et will be 56 (anymore and the wheel/tyre combination will rub on the suspension leg)
    In the perfect setting I would want to keep the centre of my wheel as near to manufactors as possible (to reduce load on bearings etc)
    If I say 56 et is the most I can have (suspension leg in the way)I can move the wheel out (away from the suspension leg by using spacers,so in some cases its better to have higher et than standard)
    The next issue is the bodywork I then increase wheel width (j size) which brings the wheel closer to the bodywork
    Wheel supplies will try to keep the wheel centreline in the same place
    so will tend to increase the et (if poss)at the same time as increasing the wheel width (j size)
    Also as they change the wheel size/width on the wheel wizard the tyre width will change as well (there are again different width tyres that will safely fit the same width wheel)
    I have confused myself now:hubbahubba:
  18. maars
    576
    Alas, yes. But let me trial fit the 19s first!
  19. maars
    576
    No supplier - they're s/h Audi 19s which I hoped would fit. I was going to run 225/35x19 tyres.
  20. dipstic
    dipstic Member
    384
    For my car 8P S3 I would assume from that wheel wizard my max wheel that would fit will have ET of 56 x 8j x19 if we then look at marrs wheels
    ET of 48 poss diff of 8mm (further away from suspension leg)
    8.5j against 8j diff of 13.5mm (wider nearer bodywork) so add the two together 21.5mm nearer the bodywork which means that they might rub on full lock or when loaded up or over bumps
    I say might because a few minor mods to bodywork might give enough room for the wheels to clear
  21. maars
    576
    Just run the check on the CarBible guide:-
    OLD - 225 tyre width, ET54
    NEW - 225 tyre width, ET48
    "The edge of the new tyre will be 6mm further away from the inside of the wheel well and suspension components, and 6mm further out from the edge of the bodywork."
  22. dipstic
    dipstic Member
    384
    Now add diff between 8j and 8.5j
  23. dipstic
    dipstic Member
    384
    So when are you going to fit them
  24. dipstic
    dipstic Member
    384
    Damn I was going out for a drive :asskicking: give myself one
  25. maars
    576
    Worse - it's the difference between 7.5J and 8.5J
    Trying them this weekend.
  26. dipstic
    dipstic Member
    384
    good luck look forward to pics
  27. sat1983
    sat1983 Member
    848
    15
    How much do different wheels weight? Any websites with the info?
    RS6 wheels?
    S3 wheels?
    Sport wheels?
    SE wheels?
    etc etc...
    Which are lightest??
  28. maars
    576
