Wheels and discs
ScottD3 Nov 26, 2011
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    I'm wondering if its possible to get a complete list up of what the minimum sized wheel will fit over what size discs. Ranging from 15" up to 20".
    I know its a question that gets asked every so often, I've even tried looking for a answer but I can't find the answer or a list similar to this one, so thought it be a good idea to start one.
    I would start but I don't know. lol
  2. Foxmeister
    Foxmeister Fired Up!
    1,785
    Although the discs do contribute to the general sizing of the wheel, its also the caliper that will dictate this, due to different manufacturers using different dimensions etc, so the list would have to be specific to each manufacturer aswell, Brembo, Wilwood etc.
    Brembos 330mm upgrade may require min 18" wheel whereas Wilwoods 330mm kit could use 17" if caliper is smaller, gonna be a big list mate!
  3. ScottD3
    15,161
    1,122
    I knew the callipers will have a bit to do with it but at the moment it be good to have a rough guide and could add callipers at a latter date if there is enough call for it.
    I'm mainly thinking about the more popualr upgrades that people do with keeping standard callipers or even the more popular caliper upgrades included as well, like 911 or boxter calipers.
    Example 288mm, 312mm, 320mm, 345mm.
    Big list or small like, could still be usefull for people.
  4. Broken Byzan
    13,237
    465
    it also depends in some cases on the offset.
    B5 S4 brakes will go under a 17" wheel, but they stick out a fair amount and as a result only fit under certain 17" wheels
    As a general rule with stock Audi Brakes:
    288mm needs a 15" rim
    312mm needs a 16" rim
    320 and 345mm need a 17" rim.
  5. jojo
    28,882
    3,536
    The question is very car specific to create a list Scott, in my opinion.
  6. garyspeed
    garyspeed New Member
    10
    I knew that the Pliers have much in common with him, but at the moment, it's good to have a sharp focus and then add the pliers, if enough call for it.
