Wheel spacers?
pilcob Apr 13, 2011
  1. pilcob
    pilcob Member
    93
    Hi all, I have a 2003 S4 with RS4 front brake conversion, the front wheels are fitted with 10mm spacers to clear the callipers, the rear wheels are standard fit with no spacers fitted.
    Do I need to fit spacers to the rear wheels, will it improve the feel/handling of the car at all?
    What size spacers do i need to fit, would you go with 10mm to match front or 15mm?
    Are the hubcentic spacers on Ebay any good? Seen some UK manufactured ones on there.
    Any advice or opinions on this would be appreciated, thanks.
  2. scott b
    scott b Active Member VCDS Map User
    1,254
    to be honest i dont think it would make a noticable difference
  3. bubstar
    bubstar Member
    550
    I've been running MTM 10mm spacers F&R for a few years now. Go for the 10's on the rear too it will just balance to look of the car so much :)
  4. quattrojames
    14,050
    577
    I'm sure visually it would benefit with spacers on the rear. The rears always sit more in the arch than the fronts. So with 10mm on the front I'd be definitely go for 10mm on the rear, that will drop the offset to 35. Spot on.
  5. DPM
    DPM Site Sponsor Site Sponsor
    5,016
    206
    The main difference would be looks and I'd say go for a 15mm spacer at the rear if you have 10mm at the front.
    Damian @ DPM Performance
  6. pilcob
    pilcob Member
    93
    Thanks for your thoughts/comments, bought pair of 15mm hubcentric spacers today, will fit as soon as they are delivered.
  7. dubdemand
    dubdemand VAG Addict
    405
    Post pics once you're done! ;)
  8. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    439
    Yeh lets see them out to the arches:eyebrows:
  9. benjie
    benjie Well-Known Member
    1,223
    305
    x3 for pics! I ordered some 10mm hubcentrics for the front the other day (from DPM) to fit some bigger brakes under, but would be interesgted to see the look of the car.
  10. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    I have 15's F and R - both huncentric and longer bolts
  11. pilcob
    pilcob Member
    93
    I will post some before and after pics when I get/fit them
  12. pilcob
    pilcob Member
    93
    Finally fitted spacers and took some photos, need to address my poor photography skills.[​IMG]
    Help, cant get pictures to work.
  13. pilcob
    pilcob Member
    93
    Try again[​IMG][/IMG]
  14. quattrojames
    14,050
    577
    Copy and paste the IMG tag if using Photobcuket, or there's a sticky in the general chat section to help you.
  15. pilcob
    pilcob Member
    93
    Followed the instructions in the thread, but still cant pictures to work.
  16. quattrojames
    14,050
    577
  17. pilcob
    pilcob Member
    93
    Rears before fitting spacers
    Fronts with 10mm Spacers fitted
    Shiney new 15mm Spacers for rears
    Couple of pics with rear spacers fitted
    Front with 10mm spacer
    View down side of car
  18. pilcob
    pilcob Member
    93
    Sorted now, got my eldest to show/teach me, he does it a different way to the way shown in the sticky.
  19. quattrojames
    14,050
    577
    It's funny how the Avus wheels have a 45 offset vs the 43 of the rest of the range (18's).
    Looks spot on now though, the 15's on the rear look exactly right. Have you got any pics of the 'whole' car?
  20. pilcob
    pilcob Member
    93
    Not got any of the car except the ones I took at the police forensics bay, will take some new ones, just need to give car a good clean first.
    This bank holiday period would have been ideal, but I chose to machine polish my longwheel base hi roof transit van instead, theres a job I wish I had'nt started.
  21. paul20v
    paul20v Audi fanatic
    1,113
    S4 discs are thicker .
  22. quattrojames
    14,050
    577
    You'll have to run that past me again..... They have thicker discs, yet the 45 ET wheels will sit closer into the discs...?
  23. paul20v
    1,113
    Thicker discs at the hub face :)
  24. quattrojames
    14,050
    577
    Ok I get you.
    (You so edited that reply between the time I first read it and later replied to it) lol!
