Wheel Spacers, Yes or No?
S3 Johnny Sep 23, 2009
  1. [Dave B]
    [Dave B] Daddy
    2,027
    145
    If you're precious about your paint work then be warned, if you go out wide on the front the tyres protude(sp) past the bottom of the arch meaning the side of your car is ripe for stone chipping. I've already started to notice it a little, hence the reason why i'm going for flaps all round...
  2. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    155
    Hope these pictures help mate Im no David Bailey!
  3. 1animal1
    9,976
    thanks for that mate.... seems they could stil come out a tad more!! it does give it a lot better stance though...
  4. ianysm
    ianysm Active Member
    1,002
    Does look alot better.
    Like the car mate..And the plate!!
  5. s3 Hoggy
    1,716
    155
    Definately gives it a better stance it's quite hard to show realy, shame I can't lower it as it scrapes coming off my driveway as it is! I think you wouldn't wanna go any wider than 20mm each side if your going to lower yours as I'd say you would touch the inside of the wheel arch,
    Cheers Matt
  6. random101
    random101 Member
    128
    Are there any 8mm-10mm hub centric spacers out there?
    or do they not bother as 8mm there is still enough hub to sit in the wheel nicely?
  7. Kingston
    Kingston Member
    183
  8. JS1500
    JS1500 Howdy
    1,166
    10
    Plenty of 10mm ones to choose from, i'm sure some places do 8mm also.
    I have anodised black 10mm fronts and 15mm rears (each side). I bought them through some engineering place, forgot the name but will find out if anyone wants the info. All in = £109 posted including longer bolts (correct length and fitment for oem wheels, no cutting).
    They make a big difference to the car's stance although it is quite hard to see in photos. The difference is very noticeable to a trained eye but I reckon 9/10 non-car-people wouldn't notice!
    I'm currently on standard suspension (won't be for too much longer) and i've noticed that over really badly surfaced roads the car is a bit more jittery and maybe tramlines a bit more than before? I'm worried the OEM suspension is taking a battering, and at 70k miles it needs replacing anyway.
    Hopefully a set of KW springs & shocks will cure all ills. Will have to report back in the new year!
  9. Westy
    Westy Well-Known Member
    17,440
    1,097
    Please post up the details of said "engineering place" as £109 all in is a bloody steal, especially for annodised ones :icon_thumright:
  10. JS1500
    JS1500 Howdy
    1,166
    10
    Sorry, thought it was initials then 'Engineering' but it's actually some intials then 'Motorsport' - more specifically;
    Philip Walker
    UK BBS importer
    P W Motorsport Ltd
    01437 563929
    I found them on eBay and just phoned them. On ebay they have sets of 4 of the same size but I wanted 2x 10mm and 2x 15mm and the correct bolts so just gave them a call.
    http://shop.ebay.co.uk/pw-motorspor...t=0&_trksid=p3911.m270.l1313&_odkw=&_osacat=0
  11. seen_
    seen_ Member
    40
    whats the PCD on an audi a3 1.8t (x reg)??
    thanks in advance!!!
  12. seen_
    seen_ Member
    40
    facelift model 8L
  13. putang
    putang Member
    154
    5x100
