wheel spacers on the s3 ??????
tvr1 Sep 23, 2003
  1. tvr1
    tvr1 Member
    49
    anyone put spacers on there s3/a3 ?
    available in sizes from about 10-70mm per axle from my findings i would prob go for 30-40 if i was to do it
    group B type are a reasonable price and i guess should help with cornering.
    what do you guys think ?
  2. NikoS3
    NikoS3 New Member
    I suggest you put at least 8mm spacer per side and be sure to get hub-centric spacers if you are using the OEM wheels.
    I have 5mm in my car, in order to clear the Porsche Brakes but these do not have the hub-centric ring and have created problems centering the wheel. I have now made by order some rings to fit OEM wheels & 5mm. spacers.
    The handling of the car has improved a lot even with a total of 1cm per axle.
    Nikos.
  3. tvr1
    tvr1 Member
    49
    thanks 4 that sounds like the way to go then
    cheers
  4. Gambba
    Gambba Active Member
    1,361
    I believe that you should be looking at a max of 12-15mm IIRC on the S3, and for me I would be looking to increase all proportionally so to keep the same basic handling characteristisc but take them to the next level.
  5. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    10mm front 15mm rear for me.
    was advised not to go larger on the front, even tho they only just clear my porsche brakes.
