Wheel spacers on S3 8L with 18" RSTT wheels
gaznogaro2003 Jun 25, 2010
  1. gaznogaro2003
    gaznogaro2003 Member
    86
    Im sure ive read somewhere people space there wheels out on here?
    Il be picking my 18" genuine RSTT wheels up shortly and want them to look spot on in the arches!
    Going to either fit coilovers or eibach springs to lower.
    Just wondering what spacers if required and what make etc.
    Pic attached also, does this have spacers fitted or standard just boltedon, and anyone know what kind of lowering kit it has?
    Gaz
  2. Chlippo
    Chlippo Member
    679
    15
    All the info you need is available at the stickies mate.
    As for a quick answer, you dont need any spacers to fit the 18 rstt in an S3
    "One" of the most recommended suspension setup (not necessary the best for you but felt the best for many many S3 users on this forum):
    Bilstein's B8 sports damp's (front + rear), eibach springs (front + rear), antiroll bars (22mm front + 19 mm rear) or VW R32 antiroll bars.
    with this setup you will: lower the car (check the stickies for the dimension's but i think its 1.5"), have a more stable and steady ride around the corners while still being comfortable, and with the arb's you will limit the understeering.
  3. s3_stig
    s3_stig Member
    376
    Front 10m rear 15m will be spot on
  4. s3 Hoggy
    s3 Hoggy Whats going on???
    1,703
    137
    I have 13mm front 20mm rear, not lowered though
  5. gez
    gez S3 hunter
    109
    5 front 15 rear is perfect
  6. <tuffty/>
    20,601
    3,594
    10mm front, 15mm rear on mine with RSTT's... looks spot on
  7. JS1500
    JS1500 Howdy
    1,166
    10
    Same as Tufty ^^^
  8. Chlippo
    Chlippo Member
    679
    15
    do you guys notice any vibration on high speeds with the spacers on?
  9. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,797
    3,457
    I'm running 5mm Fronts and 10mm rears on my 19x8 rims.
    You need hubcentric ones that centre themselves, and no vibrations.
  10. DPM
    DPM Site Sponsor Site Sponsor
    4,903
    174
    As mentioned, 5mm or 10mm up front and 15mm at the rear is pretty spot on depending on what look your going for.
    As long as you stick with good quality hubcentric spacers you'll be fine.
    Damian @ DPM Performance
  11. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Will that would be epic pal ;) Euro fan are we ;)
  12. jojo
    28,797
    3,457
    That would be a lot of 'poke' lol
