wheel spacer...
milli Aug 26, 2012
  1. milli
    milli Member
    179
    9
    Hi all, i know this has been asked a millions times, have been searching through the posts but still cant decide on which ones to go for. Just lowered my s3 on coilovers and now the rear wheels look lost in the arch so i was thinking 15mm spacers, what have people gone for?
  2. Tooks
    Tooks Active Member
    753
    30
    I've just tried 10mm front and 15mm rear on mine, but it's a mixed bag for me.
    Yes, it looks better, and I even think the rear could take 20 or 25mm to be honest. But, the steering with just 10mm on the front is what I would describe as 'corrupted'! Basically, I thought it was pants, heavier, less precision, and just felt 'wrong'. This is on the standard 17" S3 alloys.
    I'm running 10mm on the back now, but have removed the front spacers. The steering is back to how I like it, and the rears look a little less lost now too.
    Im going to look at some 18" 8.5 or 9" now, so they can fill the arches more without corrupting the steering/offsets.
  3. PaulRS3
    PaulRS3 Well-Known Member
    1,230
    156
    I Used to run 10mm front/15mm rear with Porsche big red front brakes and factory 18" wheels.
    Looked spot on with factory optional Quattro GmbH suspension the car had.
    Just remember you need longer bolts, and keep a standard set in the car for the spare if needed.
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    wheels....how wide, what offset?
  5. milli
    milli Member
    179
    9
    i have RSTT wheels on it at the moment but looking into getting some new ones after the winter is over
  6. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    Good thought there.
  7. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    20mm rear spacers on Rstt's
  8. Arnie013
    Arnie013 Member
    152
    13
    Sorry to jump in, but what spacers if any you running on the front there Hoggy?
  9. kelk11
    kelk11 Member
    112
  10. rhys1210
    rhys1210 Active Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    177
    26
    looks good, what do you have on the front?
  11. PaulRS3
    1,230
    156
    Its an option, just one I didnt want to try.
    I could only fit the spare on the rear anyway due to the Porsche brakes.
    As it happened, I kept a full size spare at home, and never needed to use the space saver.
  12. DPM
    DPM Site Sponsor Site Sponsor
    5,065
    224
    If you're wanting to get new wheels then it may be best to wait. If you're wanting them for your current wheels then I'd say 10mm front and 20mm rear.
    Damian @ DPM Performance
  13. milli
    milli Member
    179
    9
    Well i know which wheels i want, so if anyone can work out how big a spacer i will need then i can go ahead and buy the ones i need. Wheel spec is 9.5J ET23?
  14. s3 Hoggy
    1,716
    158
    Sorry mate only just seen this, I have 11mm on the front now, I did run 13mm but they went all rusty/corroded can't see a difference
  15. Arnie013
    Arnie013 Member
    152
    13
    No dramas bud. Cheers!
  16. DPM
    5,065
    224
    You may not need spacers at all with those wheels.
  17. blackshuck
    blackshuck Member
    440
    HI there, im new to the forum today and picked up this S3 on Monday but I was thinking it could do with spacers, any idea what I can use with these wheels? I think there RS4
  18. DPM
    5,065
    224
    What's the width and offset on them?
  19. blackshuck
    blackshuck Member
    440
    Hi Damian, thanks for the reply, good question I will pop a wheel off over the weekend and have a look!
  20. blackshuck
    blackshuck Member
    440
    I'm no wheel off so far the car came with locking wheel nuts but no key! Oops!
  21. blackshuck
    blackshuck Member
    440
    ImageUploadedByTapatalk1362948287.096095.jpg ImageUploadedByTapatalk1362948298.695049.jpg
  22. blackshuck
    blackshuck Member
    440
    Bump
