Wheel Spacer problems
sturs4 Oct 17, 2011
  1. sturs4
    sturs4 Member
    193
    9
    Im running 20mm spacers on my S3.Nearly one thread on each spacer has stripped just torquing the bolts up.Has anyone else had a similar problem?
    Ive just given my self the fear of going round a corner and my wheel departing from the car,plus its on the rollers on saturday and i want it to be sound before hand.Im going to replace them but if this problem is a regular occurrence i'm not going to bother.
    cheers
  2. Lund
    Lund Member
    153
    They sound cheap and nasty to me despite how much you may have paid. Find a supplier who will supply you with a set of stainless reinforced jobbies.
  3. sturs4
    sturs4 Member
    193
    9
  4. Lund
    Lund Member
    153
  5. sturs4
    sturs4 Member
    193
    9
    Sadly i need them for my Maybachs to fit.
  6. Lund
    Lund Member
    153
    As you say you're probably better off with the Eibach's then as they're hubcentric and shouldn't cause too many adverse problems.
  7. crunchie
    crunchie Active Member
    880
    77
    Surely 20 mm spacer will eat wheel bearings!
  8. 1inchpunch
    1inchpunch Member
    451
    If your wheels need 20mm spacers to fit then I would suggest the spacers aren't the problem. Get some wheels that fit properly.
  9. c_w
    c_w Well-Known Member
    1,163
    87
    If the spacers are the sandwich type that are clamped between the wheel and the hub, surely it is the wheelbolts that are the issue? I take it you have the correct length longer bolts?
  10. sturs4
    sturs4 Member
    193
    9
    They are the type that bolt to the hub then the wheel bolts to the spacer.Having them on isnt gonna be an issue as its bringing the ET of the alloy to standard fitment.Its a case of **** quality spacers i think.You can make anything fit properly,its just finding the right quality parts to do so,thats why im asking.
  11. Ash B
    Ash B Well-Known Member
    5,831
    Pm N8 im sure he will be able to tell you what spacers to use and not use.
  12. Rob-Quattro
    Rob-Quattro Member
    220
    12
    What kind of post is that??? :wtf:
  13. 1inchpunch
    1inchpunch Member
    451
    Consider it a public health information post :) I don't really want to see the OP die when his wheel falls off. The spacers he has are clearly made of toffee or something.
    I have nothing against spacers but please use good ones. If you really want to fit those wheels then get H&R or Eibach spacers or anything else that is TUV approved and hubcentric rather than the kind you have. It will require longer bolts as well so will work out more expensive but will be safer.
  14. c_w
    1,163
    87
    For those kind of spacers I would use H&R, I had some of those on another car and they seemed top quality. I didn't think the cheapo makes bothered making those kind though! I think I bought them from Performance Car Parts / EBC Brakes / Eibach Lowering Springs / Koni Suspension Kits / Magnex Exhausts / Powertec Induction Kits - Euro Performance or something like that. These kits come with the bolts as they are specific to the spacer so seem better value than the traditional sandwiched spacer.
  15. sturs4
    sturs4 Member
    193
    9
    Ive gone for hubcentric spacers with longer bolts.ive been told this is the best way of doing it on something like a S3 because the wheels are going to be bolted straight to the hub and not the spacer making it much stronger.
  16. brough74
    brough74 Member
    423
    22
    One of my longers bolts did the same when i changed tyres over, luckily i had a spare due to fitting longer locking bolts. I swapped it over and its fine. Basically if all of them torque up ok then you will have no issues
