wheel spacer and spring tips needed please.
slim boi
scunthorpe
As above what's a good spacer size and make for an sline avant on 18's and same with springs. Dont want ride to low as its still the family car and may change wheels to 19's at some point.
As it is now.
5mm front, 10mm rear and a 50mm drop, it sounds like alot but its honestly not. mine is down 50mm and you can still see the tops of the tyres.
S-lines are already 25mm lower than standard and all spring/dampers are quoted figures for the SE so a set of 50mm springs will actually only lower your car 25mm.
go with Weitec, Eibach or H&R and they will be more comfortable than your standard set up.
as for spacers make sure you get hubcentric to avoid your wheels vibrating.
youll find pics of mine on the last page of the show us your A4/S4 B7 section for reference.
No worries pal and thanks. keep us up to date with your progress!
