wheel refurb
armytdi Feb 1, 2006
  1. armytdi
    armytdi Member
    54
    looking at buying a set of \oem RS4s, in dire need of refurb. how much am i likely to pay for a full set- as much as £50 per corner??
  2. easytease
    easytease cheesypeas
    433
    depends on a lot. if you take just the wheels to the place they'll charge a lot less then is you took the car down there. as then they'd have to remove the wheels and take the tyres off.
    its something i need to do to my A4 in the summer too
  3. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    It may also depend on how "complicated" the alloys are
    I was quoted £35 each for a set of S3 alloys
  4. armytdi
    armytdi Member
    54
    so generally, an S3 alloy is likely to be less than an RS4? the noes im' looking at are without tyres, and obviously not fitted to a car
  5. MikeA3
    1,178
    When i go mine done the way the guy explained it was that due to a S3's fairly simple 6 spoke design, they could do them faster than (for example) a RS4 design so it cost less.
    As said above, if you can deliver the alloys to them, that should save you some cash as well.
    hope it helps
    Mike
  6. armytdi
    armytdi Member
    54
    thanks mike
