Wheel question
gaz71 Mar 13, 2010
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    I've found some Mercedes Vito alloys at a local scrapyard in good nick and going cheap.
    They are 17", 8.5J with offset 35.
    Would they fit my B5?
    Need some wheel asap as my originals are badly in need of refurbing. The lacquer is missing from large sections on all 5 and I am having to check pressures and pump up every few days.
  2. aragorn
    18,382
    831
    they are a bit wide for a b5, but probably would squeeze on.
  3. gaz71
    286
    So you reckon they'll fit, hmmm, liking that.
    Would I need any spacers, planning on fitting the 225/17/45's that are currently on my shabby 17's
  4. gaz71
    286
    Bugger, they've gone :sob:
  5. Geeman
    Geeman Low Life
    1,318
    Bugger.
    But... ET35 would be okay on the back, but you might have trouble with the fronts. But... it all depends on what tyre sizes you fit and how low your car is.
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I was going to say the other way round.
    My 8.5x18's clear the front strut and arches no problem, rears are little snug but it is nice and firm so doesn't rub
  7. Geeman
    Geeman Low Life
    1,318
    I was running 8.5" Fat5's before the monos... I had 10mm rear spacers and nothing on the front... but they were ET45 - hence why I thought the ET35 Merc rims would stick out a bit at the front!
  8. jcb
    4,132
    13
    mine are ET24.... no worries ;)
