Wheel offset
Stuart35205 Jun 3, 2013
  1. Stuart35205
    Stuart35205 Member
    108
    As above! How do I work out the current offset I am running if its no stamped on the LM reps that are on there at the mo? It has hub centric spacers aswell 10mm front & 15mm rear which I gather I take off the alloy wheel offset?
    Regars Stuart
  2. Stuart35205
    Stuart35205 Member
    108
    I had the wheel of again just to make sure & there is no marker sayin ET--? Just says 18x8j can I measure this some how? Cheers
  3. <tuffty/>
    21,572
    4,047
  4. Stuart35205
    Stuart35205 Member
    108
    Cheers tuffty , so I worked out my offset of the current alloys are et35 with 10mm spacer on front that makes it et45? & 15 mm spacer on rear is et50 does that sound right ? Just trying to work out the clearances I have & offset/spacers req'd for new wheels! Cheers
  5. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,277
    362
    sorry, are you saynig the offset of the wheel is 35mm or the offset of the wheel with spacer attached is 35mm??
  6. Shaunie Eire
    Shaunie Eire Member
    78
    If the wheel is et35 and you add a 10mm spacer your overall et is 25.
  7. Westy
    Westy Well-Known Member
    17,443
    1,105
    This is correct. Remove the spacer width from your wheel ET.
    ET35 -10 (spacer) =ET25
  8. Stuart35205
    Stuart35205 Member
    108
    My bad cheers all , I was looking to put staggered wheels on & possibly squeeze 9.5 or 10" on the back and possibly 8.5 on front with the current setup the car has a really good stance which I'd like to keep.
