Wheel offset question
Syncopix Mar 12, 2010
  1. Syncopix
    Syncopix OEM+
    93
    Would a set of 18 x 9 inch wheels with an offset of 52 fit the B6?
  2. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    not sure a 52 would, im running 18 x 8.5 with a 35 offset
  3. swarcup
    swarcup Well-Known Member
    1,326
    40
    i think you would rub on the inside with 52 but with a 10mm spacer each side would make the offset 42mm then so with the spacers yes they will. someone confirm this
  4. dannyFR+tdi
    dannyFR+tdi Member
    212
    Im running 19x9 at ET42 fronts and ET 37 (i think) rear with a 5mm spacer, I think you would need spacers to get to around the ET42 mark so you dont rub the caliper as i know mine sit quite close, theres pics of mine in members rides if you want to look to get an idea of how they sit
  5. N8
    17,163
    718
    Run a spacer as mentioned...
  6. N8
    17,163
    718
    Yours been shaved? As your wheels are ET41...
  7. Syncopix
    Syncopix OEM+
    93
    I want to get them close to the arch (without rubbing). Danny -- would I be able to run 20mm spaces? Or is that going to be a bit much?
    By the way - thanks for all the help guys (and girls)
